Go to Post You think you are building robots, but you are really building yourselves. - sanddrag [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
  #16   Spotlight this post!
Unread 12-02-2012, 11:22
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Re: Rendering Takes Too Long!
Originally Posted by 240 Animation View Post
And somewhere the "specs" will be listed? I'm not good with the inner workings of computers.
Yup, it should be fairly obvious once you do it. Should look something like this;
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
  #17   Spotlight this post!
Unread 13-02-2012, 18:23
240 Animation's Avatar
240 Animation 240 Animation is offline
AKA: Celia and Brynn
FRC #0240 (T.E.M.P.E.S.T.)
Team Role: Animator
Rookie Year: 2012
240 Animation is an unknown quantity at this point
We have:
Intel Core I5
4gb DDR3 RAM
We use Windows XP Pro 32-bit, SP3
  #18   Spotlight this post!
Unread 13-02-2012, 18:30
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
I'm not surprised. Ours took HOURS and we have a high end 12g RAM, 3.07GHZ, Intel XEON processor workstation.
I'd plan on starting it at the end of your day and let it run all night, and the next morning, if necessary.....
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
  #19   Spotlight this post!
Unread 13-02-2012, 18:52
Team Role: Animator
Rookie Year: 2012
Unfortunately, that is not an option for us. Right now, we've got it down to one frame every thirty minutes (2 min improvement) by simplifying our objects. We just don't know what else to do to speed it up.
  #20   Spotlight this post!
Unread 14-02-2012, 17:55
playbass06 playbass06 is offline
"bass" as in the guitar, not a fish
AKA: Chris Schaaf
FRC #1986 (Team Titanium)
Team Role: Animator
playbass06 is an unknown quantity at this point
Send a message via AIM to playbass06 Send a message via Yahoo to playbass06
Well, what renderer are you using? I'd assume mentalray?
If you can, switch over to Arch&Design shaders, and try to use "Glossy Reflections" on as many areas as you can for reflective surfaces. They save time. Depth of Field and motion blur effects are also things to be avoided, they'll easily make render times 10x what they were (depending on the # of samples).
I've spent a good amount of time optimizing our scenes with these materials, and it's usually around 2:45 (min:sec) per frame at 720p (but our setup is a 3.2 GHz i7 and 8GB DDR3 RAM). But if you're spending half an hour on one frame... you've got a lot of stuff in there. How many faces are in your scene? Ours is just over 250,000. If yours is significantly above that (>1mil) you may want to do some serious poly reduction. Do you have any other machines/licenses of 3ds Max? Use Backburner to do some network rendering.
And, just out of curiosity, why are you doing over 1000 frames? The video is limited to 30 seconds, which at 24 frames/second, would amount to 720 frames maximum.
Good luck, hope you get the render times down.
Last edited by playbass06 : 14-02-2012 at 17:59. Reason: misjudged our render times
  #21   Spotlight this post!
Unread 14-02-2012, 18:13
Team Role: Animator
Rookie Year: 2012
We are using scanline instead of mentalray because mentalray kept crashing our program.
Our other scenes, actually, take less than four minutes. We also edited our objects to be more simple.
We added our intro, slate, and credit so it bumped up the frame count.
Thank your for your help.
  #22   Spotlight this post!
Unread 14-02-2012, 18:20
AKA: Chris Schaaf
Team Role: Animator
Ah, okay. Thought it might be that, but thought I'd just double-check.
  #23   Spotlight this post!
Unread 14-02-2012, 18:37
Team Role: Animator
Rookie Year: 2012
I think we are going to take out the credits and add them in Movie Maker (or something like that). That should definitely speed things up, right?
  #24   Spotlight this post!
Unread 14-02-2012, 21:03
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
Yes, that would be faster. You can do cool stuff in 3DS MAX though. Our prototype credits explode for instance (not sure if we are going to use them though)
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
  #25   Spotlight this post!
Unread 18-02-2012, 09:04
Team Role: Animator
Rookie Year: 2012
Thank you, everyone, for your help. We are now rendering at approximately twelve seconds per frame. Hooray!
  #26   Spotlight this post!
Unread 19-02-2012, 17:19
SCRktkt SCRktkt is offline
SCRktkt is an unknown quantity at this point
Welcome to rendering. Here are some things to try:
1. Plan on adding depth of field blur in post. This will allow you to use a cheaper anti-aliasing, such as Box instead of Gauss or Mitchell.
2. Experiment with composite renders for shorter times. For many scenes, you can hide the characters, and run the final gather once at a high accuracy. Then freeze the final gather, and render the camera moving in the environment. In a separate render, using the mental ray matte/shadow material on the environment, render just the characters. The images can be composited and adjusted easily in post.
3. For your Arch & Design materials, dial down the reflection interpolation for everything you can.
If you need more help, post here and I'll see what I can suggest; images of your work will help.
Adam Crespi
Autodesk Certification Evaluator
Instructor, The Art Institute of Seattle
  #27   Spotlight this post!
Unread 21-02-2012, 15:51
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
We were rendering in Mental ray with lights set with low res shadow maps (512) of course, they looked bad, so we switched to ray traced shadows. That took too long. But then we changed to advanced mentalray shadow maps at 2048 and it looked good AND rendered faster. I was surprised that in some cases, MR renders faster than scanline.
  #28   Spotlight this post!
Unread 21-02-2012, 19:24
Team Role: Animator
Rookie Year: 2012
We have finished rendering our animation, but this advice will certainly come in handy next year =)
