Go to Post My teams robots have been good, bad and ugly BUT they were all beautiful because they were there. - JohnBoucher [more]
Unread 11-02-2012, 17:48
Luiz12 Luiz12 is offline
FRC #4210
Luiz12 is an unknown quantity at this point
Microswitch program..
Basically I want to press a button and let go but the motor begins to run until the switch is activated then I want it to roll back for 5 seconds. Can someone give me an example on how to do this using Labview.
Unread 11-02-2012, 17:58
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Rookie Year: 2011
Keyreaper is an unknown quantity at this point
Re: Microswitch program..
Is this what you are trying to accomplish? I think some other programmers on here could help out and also make sure I haven't made mistakes....
http://imgur.com/a/oSPD4
Unread 11-02-2012, 18:20
FRC #4210
Yes thank you..
Unread 11-02-2012, 18:32
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Rookie Year: 2011
Originally Posted by Luiz12 View Post
Yes thank you..
I'm not sure it actually works, as I don't normally work with the wait.vi function so I'd build it up just to make sure.
Unread 19-02-2012, 20:20
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
Rookie Year: 2010
MAldridge will become famous soon enoughMAldridge will become famous soon enough
make sure you don't put that in teleop. That wait will stall out the loop.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
Unread 19-02-2012, 20:29
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Rookie Year: 2011
He is correct... Perhaps a Elapsed timer would work better.
Unread 19-02-2012, 20:32
MAldridge's Avatar
Lead Programmer
AKA: Rube #1
Rookie Year: 2010
actually, you would do good to do it the way you have it here, but throw it into a separate loop in periodic tasks. There is no good way that I have found yet to do a delay on the cRIO without running it in parallel. Mainly because the timestamp is kind of flakey.
