Go to Post Being a part of FIRST is inspirational regardless of what else happens. - Jon Stratis [more]
  #16   Spotlight this post!
Unread 12-02-2012, 08:59
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Team Role: Teacher
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Re: How are you pushing down bridge?
Van door motor gear down.
http://www.youtube.com/watch?v=BQ1mG...ature=youtu.be
No need to lift your robot off the ground if down right.
Building FIRST robots since 1995
BVT Robotics
  #17   Spotlight this post!
Unread 12-02-2012, 09:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Originally Posted by wireties View Post
FORST Team 1296 is using a van door motor geared up a bit to push down an arm made with 1" square aluminum extrusion. The arm is 2-pronged, we are hoping a ball (on the bridge) might roll between the prongs and into the gatherer.
You might want to make sure it will count as one appendage, not two. There's been a lot of discussion about this here and on Q&A. It's my understanding that a two pronged thingy is considered two appendages (and thus illegal) unless it's all one contiguous piece outside of the frame perimeter, even as it deploys.
  #18   Spotlight this post!
Unread 12-02-2012, 10:09
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
It is one appendage leaving the perimeter that spits it into two equal-sized forks ... what on earth might contiguous mean in this context? It is solid, no articulating etc.
Fast, cheap or working - pick any two!
  #19   Spotlight this post!
Unread 12-02-2012, 10:17
MrForbes's Avatar
AKA: Jim
I wonder if pictures would help?
I think it means that the part outside the frame perimeter is all connected together.
But I'm not as imaginative as the GDC....
  #20   Spotlight this post!
Unread 12-02-2012, 11:35
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Out being welded but will post the cad later
  #21   Spotlight this post!
Unread 12-02-2012, 12:29
tux tux is offline
AKA: Lee Harr
FRC #3842 (Shock-a-Bots)
tux is an unknown quantity at this point
I am also having a problem with "contiguous" (as mentioned in the G21 team update).
Our extension is sort of like a pair of salad tongs. One of the tongs is articulated. The two tongs do not contact each other directly, but they are both connected to one other piece. In other words, they cannot be deployed separately. They are both part of one mechanism that is deployed as a single unit. Is that contiguous?
  #22   Spotlight this post!
Unread 12-02-2012, 12:32
tux tux is offline
AKA: Lee Harr
Wups. I think this may be a better place for my question:
http://www.chiefdelphi.com/forums/sh...d.php?t=102627
  #23   Spotlight this post!
Unread 12-02-2012, 12:33
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Depends on where they connect. If they connect inside the frame then it is my understanding that it is not a contiguous appendage. However, if they fork outside of the frame, then they are considered contiguous.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
  #24   Spotlight this post!
Unread 12-02-2012, 18:50
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Look OK? And what if we add a little wheel on each fork?
  #25   Spotlight this post!
Unread 12-02-2012, 19:08
CalTran's Avatar
MST Rolla Senior
Rookie Year: 2010
Rule posting to follow:
[G21]
Robots may extend one appendage up to 14 in. beyond a single edge of their frame perimeter at any time.
Violation: Foul for exceeding size allotments; Technical-Foul for continuous or repeated violations.
[Blue Box]
These appendages are intended for use in manipulating Basketballs and/or Bridges. A Robot may have multiple extension devices onboard, but only one may be deployed at a given time.
All portions of an appendage that are outside the Frame Perimeter must be contiguous with each other. Very brief violations of the contiguity requirement as a single appendage is being extended or retracted will not be penalized.
[/Blue Box]
Emphasis mine. From the picture, it would appear that it is contiguous within the frame, and the two forks of the appendage cross at two separate points of your frame. So, I'm not sure, but I do not believe this would qualify as a contiguous appendage.
  #26   Spotlight this post!
Unread 12-02-2012, 19:13
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Hey - thanks for looking at it. We sure appreciate the advice. It is hard to tell from this rendering but the cross piece is outside the frame when extended. It is is roughly (vertically) over the edge of the bumpers. The frame is all 1x1 Al extrusion - see it running behind the rendered bumpers?
TIA
  #27   Spotlight this post!
Unread 12-02-2012, 19:15
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
yeah.
cole?
  #28   Spotlight this post!
Unread 12-02-2012, 19:16
MrForbes's Avatar
AKA: Jim
So use pneumatics to actuate your appendage
  #29   Spotlight this post!
Unread 12-02-2012, 20:27
tux tux is offline
AKA: Lee Harr
Look OK?
Looks a lot like what we have. I guess now it depends on the definition of "very brief," how quickly the mechanism deploys, and probably on which inspector you get on game day.
I think the wheels are much less of a concern than the 2 prongs of the fork.
