Go to Post All the powerhouse teams will be having powerhouses dinners with each other in the powerhouse restaurants, probably. - T^2 [more]
Unread 11-02-2012, 20:14
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
BoundingRect Height
Hello, does anyone know how to get the BoundingRect Height data for a particle in the vision analysis. My team used a vector<particleanalysisreport> but all we could find was boundingRect which did not tell us anything.
Unread 11-02-2012, 23:33
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: BoundingRect Height
Sure thing. When you get the vector back, I'll assume (for the moment) that you can iterate through the vector and get the ParticleAnalysisReport objects back...
Code:
ParticleAnalysisReport& par = (*vPAR)[i];
int h = par.boundingRect.Height;
I am doing this a bit from memory earlier today - but basically there is a "Rect" structure which is what boundingRect is within the Report class. It has Top/Left/Width/Height.
That's the ticket.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 13-02-2012, 06:58
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
The definition of Rect is in WPILib\nivision.h
Code:
typedef struct Rect_struct {
    int top;    //Location of the top edge of the rectangle.
    int left;   //Location of the left edge of the rectangle.
    int height; //Height of the rectangle.
    int width;  //Width of the rectangle.
} Rect;
Unread 13-02-2012, 11:41
Da' Mentor Man
FRC #1967
Rookie Year: 2007
Thanks Mike for the official word. :-)
bob
Unread 15-02-2012, 08:31
FRC #0486
Thanks for the help. If I know a particle location in the vector like
int particle
vector->at(particle); //particle is the particle number i want
is the correct sysntax to get the boundingrect height
ParticleAnalysisReport& par = (*vector)[particle];
int h= par.boundingRect.height;
Unread 15-02-2012, 14:16
mikets's Avatar
Software Engineer
Code:
ParticleAnalysisReport *p;
int rectWidth;
int rectHeight;
for (unsigned i = 0; i < particles->size(); i++)
    p = &(particles->at(i));
    rectWidth = p->boundingRect.width;
    rectHeight = p->boundingRect.height;
