Go to Post A clean pit is a happy pit, a clean pit is a controlled pit, a clean pit is a safe pit. - DjAlamose [more]
Unread 11-02-2012, 22:26
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Using a Gyro on any port (How to code that)?
The title pretty much says it. We are trying to use three Gyros on our bot this year, but we understand that there are only two available hardware accumulators on the robot. Since this is getting down to the wire, has anyone already written some JAVA for this to just take the analog signal from the gyro? We tried for a good deal of time today with no avail.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-02-2012, 23:17
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
Rookie Year: 2011
sand500 is an unknown quantity at this point
Re: Using a Gyro on any port (How to code that)?
make sure your gyro is plugged into an Analog Breakout.
Then, just use the gyro class in java and it should work.
assuming you are using the gryo that comes attached to the accelerometer.
Unread 11-02-2012, 23:23
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
That works great for the first two, but there are only two accumulators in the FPGA so you can only use two instances of the built in gyro class
Unread 12-02-2012, 03:41
ItzWarty ItzWarty is offline
FRC #1072 (Harker Robotics)
Team Role: Leadership
Rookie Year: 2010
ItzWarty is an unknown quantity at this point
The throw new Exception() of AnalogChannel.java line 229 states (if executed):
"Accumulators are only available on slot 1 on channels 1,2"
Unread 12-02-2012, 08:37
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
If you only need low performance from the third gyro you could try integrating the output yourself. Allocate a regular AnalogChannel, poll it regularly, and add the values up.
Code:
pseudocode:
thisSample = gyroAnalog.getValue
thisTimeStamp = Timer.getTimestamp
thisAmountTurned = ((thisSample + lastSample)/2) * (thisTimestamp - lastTimestamp) * (Kgyro)
currentHeading += thisAmountTurned
lastSample = thisSample
lastTimeStamp = thisTimeStamp
lather, rinse, repeat
I doubt you will get performance anywhere near the FPGA, but it is pretty quick to try.
Unread 12-02-2012, 14:51
Rookie Year: 2010
Code:
pseudocode:
If you're running anything else on your robot, it might be worthwhile to run this on a separate thread. I'm not sure how nice Thread.Sleep() is on the robot, though.
Leader of Team 1072. Software developer of RAF Manager.
Follow me on Twitter: Twitter.com/ItzWarty/
