Go to Post If you're a spectator that's going to complain about a "bad" call, you darn well better know for a FACT that the call was "bad". - AmyPrib [more]
Unread 12-02-2012, 12:34
OB1 OB1 is offline
FRC #2836
OB1 is an unknown quantity at this point
NI Vision Assistant help
Hello. We are attempting to use NI Vision Assistant to generate code to be used in our java program. We were able to set the color range values, however, we do not know how to create the convex hull operation and finding the actual rectangles.
Thank you for your help.
