Go to Post If it's anything that FIRST's competitive spirit has taught me, its to take the good with the bad. - Mike Schroeder [more]
Unread 12-02-2012, 14:36
innoying innoying is offline
FRC #2264 (inceptus)
Team Role: Leadership
Rookie Year: 2010
innoying is an unknown quantity at this point
Running PD Board from an outlet
The battery I have with me has completely died for our test programming/electrical board.
I was wondering if I could run the PD Board from power from an outlet instead? Obviously not directly connected.
I was thinking one of those AC to DC Car lighter convertors. It would still be 12 volts. Here's an example http://www.amazon.com/Universal-Ciga...ref=pd_sxp_f_i
I have one of those around.
Has anybody tried this and been successful? Or is it just a really bad idea.
Unread 12-02-2012, 14:46
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
Rookie Year: 2010
baronep is on a distinguished road
Re: Running PD Board from an outlet
I doubt that would get you enough current do run anything. You might be able to run the cRio and digital sidecar, but certainly not any motors. The CIMS (on the robot) are wired to 40 amp breakers, I doubt that even puts out 1 or 2 amps.
Unread 12-02-2012, 14:51
Rookie Year: 2010
We have no motors or Jaguars hooked up. Only the cRIO and a digital sidecar. Everything else is either not connected or already powered via a power strip on the board.
Unread 12-02-2012, 14:55
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Some of the switching supplies in the PDB are not very friendly to this approach. I strongly recommend staying away from it unless you really know what you're doing.
Unread 12-02-2012, 15:01
Rookie Year: 2010
By "not friendly" you mean they are only going to work for a specific setup? If so, what is it looking for? I've moved on to the idea of using a laptop 12 volt power supply instead as it would probably be closer to the correct voltage and provide enough current. If I knew what they are looking for I can try a different power supply that is more appropriate easily.
Unread 12-02-2012, 15:07
aire aire is offline
aire is an unknown quantity at this point
Could you use a desktop power supply like this to power the whole robot with motors and all? At 12V/135A, it provides more current than the main breaker can handle anyway, right?
Unread 12-02-2012, 15:15
Rookie Year: 2010
Where did your 135A stat come from?
Unread 12-02-2012, 15:21
12V@135A is listed on the spec page on newegg for the linked power supply.
Unread 12-02-2012, 15:30
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
A pc power supply like the one from newegg could run the robot.
to power it on, connect the thin green wire to ground on the motherboard connector.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 12-02-2012, 16:31
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
If you just want to program things and not make anything move, any clean 12V >30W power supply will do. The original part linked is likely to put out incredibly dirty power, I would not try it. The power supply module linked will likely work nicely.
Be sure not to use the battery charger as a make shift power adapter - they can interact poorly.
Unread 12-02-2012, 16:57
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
If you're making and buying things, why not just get an extra charger, it will likely have more uses to you and your team.
KK4KQO
http://voltair.us
Too many projects, too little time.
