Go to Post Life can be painfully short and you never know how things could change in an instant. It never hurts to say thank you. - Karthik [more]
Unread 12-02-2012, 18:16
vraimondi94 vraimondi94 is offline
AKA: Vin Raimondi
FRC #1396 (Pyrobots)
vraimondi94 is an unknown quantity at this point
Jaguars not functioning with CIM motors
My team decided to go with a two motor drive train using tankdrive. However, every time we try to run our robot the robot moves only a little bit and then the jaguars reset themselves. After the 3 secs the robot moves sluggish and will only move forward when you gently tilt the joystick forward. I am not too sure if this is an electrical problem or programming problem. I also saw that the jaguars resetting might be due to the CIM motor taking on too much or the jaguars drawing too much current. Any advice would help.
