Go to Post There are few times I sleep so soundly as I do after an FRC build season and regional. - JamesCH95 [more]
Unread 12-02-2012, 18:17
DFZXA DFZXA is offline
FRC #3055 (Furious George)
Rookie Year: 2007
DFZXA is infamous around these parts
PWM voltage control
I know that when using the motorcontrolsetoutput.vi that we can set the scaled pwm value from negative 1 to 1, but how exactly does that convert to the voltage that is being put out to the motor? Is there some equation for this or what? I'm basically trying to do this to try and control the speed of the motor. I know I could do this with CAN, but I don't have the wiring for it.
Unread 12-02-2012, 18:37
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
Team Role: Leadership
Rookie Year: 2010
baronep is on a distinguished road
Re: PWM voltage control
PWM doesn't actually change the voltage directly. It is just a signal to communicate with the motor controllers (Victors/Jags). Here is in explanation of how PWM works...http://en.wikipedia.org/wiki/Pulse-width_modulation
Unread 12-02-2012, 18:46
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
For a jaguar, a good first pass approximation is "applied voltage = battery voltage * signal (scaled 0..1).
A Victor is similar 0 and 1, but applies a larger effective voltage than expected in between.
For both, don't forget about the resistances involved.
Unread 13-02-2012, 11:02
Rookie Year: 2007
Thanks to both of you. I understand it a lot more now and I'm sure I can do it.
