Go to Post We are different, on purpose, for a reason. No one in FIRST should EVER forget that. - Rich Kressly [more]
Unread 12-02-2012, 19:48
Gnome2013's Avatar
Gnome2013 Gnome2013 is offline
Gnomies
FRC #2013 (Cyber Gnomes)
Gnome2013 is an unknown quantity at this point
Relay Button Issue
We have two buttons that control one spike but in the code only one works if the other is commented out. How should we go about fixing this?
Unread 12-02-2012, 21:09
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Relay Button Issue
Well, the first thing you could do is show us your code.
Unread 12-02-2012, 21:25
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Well, I coded an on/off switch recently and I came up with a one button toggle after a two button toggle.
Code:
public void teleopPeriodic()
    boolean spikeToggle = false;
    spike.set(Relay.Value.kOff);
    if(joy1.getRawButton(BUTTON_NUM)) //set the button to activate motor for the joystick
        if(spikeToggle == false) // if the toggle is off, set to true and activate motor
            spikeToggle = true;
            spike.set(Relay.Value.kOn);
        Timer.delay(0.5); // cannot change the value within the first half second of activating, you can change value but it is here to have a safe toggle without toggling every millisecond
        else if(spikeToggle == true) // if the motor is on, turn it off and it is set to false
        Timer.delay(0.5); // again it stalls the change for convenience and safety
Two buttons were crazy, but if you want two buttons, just replace the else if with the if statement and add it to the second button loop. Hope this helped.
If you have any questions and comments, just reply or post, etc.
Happy Competitions!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 14-02-2012, 19:55
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
So, what is the problem? I assume you fixed it? Regardless, you might want to create a separate thread in teleOp periodic since you have the 0.5s delays in there.
I'm a mentor looking for a home in Southern California! I know Java, C++, electrical and mechanical.
Need Java or C++ help? Send me a PM!
Unread 15-02-2012, 10:50
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
Here is how I did one button with CommandBased
Use something like (its explained in the OI class):
Code:
ButtonObject.whenPressed(new ToggleSpike());
then inside the command my code:
Code:
private boolean state = false;
    private boolean previousState = true;
    public SetFeedBelt() {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
        requires(feedBelt);
    // Called just before this Command runs the first time
    protected void initialize() {
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        state = !state;
        feedBelt.setBelt(state);
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        if(state != previousState) {
            return true;
        } else {
            return false;
    // Called once after isFinished returns true
    protected void end() {
        previousState = state;
So with two buttons make it two button.whenPressed(new onOrOffCommand()); and two commands, and if they require the spike subsystem it will handle the interrupts for you.
