Go to Post Just like a mentor used to call a deburring tool, the whirlygig....it just sticks. Also, whirlygig....what a sweet name for a tool. - Stephen Kowski [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:45
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
heat sinks
Posted by James Jones.
Engineer on team #267, The Demolition Squad, from North Broward & St Andrews and Motorola.
Posted on 1/21/2000 1:42 PM MST
Are these sleeves on the drill and FP motors really needed? I hear them referred to as heat sinks but it is hard for me to imagine that they significantly impact the temperature rise time of the motor, Do they serve another purpose? More importantly, do the motors work better with them or without them?
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Not heat sinks...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 1/22/2000 4:21 AM MST
In Reply to: heat sinks posted by James Jones on 1/21/2000 1:42 PM MST:
Those are not heat sinks.
They are used to change the magnetic field of the permanent magnets in the motor. They can improve the output of the motor by 10-20% (depending on the particulars of the motor & magnets).
Anyway, I would not recommend that you remove them.
Joe J.
[IMG] code is Off
can motors be modified ronnie_82 Motors 37 07-01-2003 08:09
'IT' info... archiver 2001 19 24-06-2002 01:58
New IT info? Mike Soukup Dean Kamen's Inventions 10 08-12-2001 23:03
Heat sinks Tech Fusion Off-Season Events 2 11-11-2001 19:57
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
