Go to Post You can take the man out of FIRST, but you can't take FIRST out of the man. - George1902 [more]
Unread 13-02-2012, 08:44
redarrowmentor redarrowmentor is offline
FRC #3234
redarrowmentor is an unknown quantity at this point
Thread pitch of acme screw
Can anyone tell me what thread pitch for the larger acme screw that acme in the kit of parts is? I want to order a tap for it but not sure what it is and I don't have one here.
Thanks!
Unread 13-02-2012, 10:29
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Re: Thread pitch of acme screw
The "pitch" of a lead screw is determined by a) its lead and b) the number of independent screw starts. The lead is defined by the axial distance the nut advances in one revolution of the screw. Pitch = Lead / Starts.
I believe that the larger KOP lead screw is this model. If that's the case, the screw has a 0.125" lead. I believe it has 5 screw starts, but I can't find any data to verify this.
As for tapping this thread-- although it's possible in theory and practice, it would be easier and less costly to just buy a flanged nut from the manufacturer and mount it as required.
Unread 13-02-2012, 10:34
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
that's going to be an expensive tap. I'm not finding it in the KOP checklist, so I'll have to defer to whichever team can measure it first.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 13-02-2012, 10:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I don't see a lead screw in the KOP checklist. Was it from a previous year?
Anyways....generally, you don't tap holes for lead screws, you use a special nut that matches the lead screw.
Unread 13-02-2012, 11:24
FRC #2363
Team Role: Coach
Rookie Year: 1999
Yes (2009), and it was also in this year's FIRST Choice. I believe 2010 and 2011's kit included the smaller (3/8") lead screw.
