Go to Post OMG this topic again. Those who stir the pot should lick the spoon. - nuggetsyl [more]
Unread 13-02-2012, 14:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Victor reversed wiring...
Hi all,
Do to a mistake in our wiring we wired up 4 victors the wrong direction.
We had the M+/- wired to the PDB. [Did not cross red/black] Then when we turned the power on the wheels started spinning right away, and after fixing it the victors seem to come out damage free.
Is there some kind of protection for this built in? Or should we toss them now, even though they appear to still work fine?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 13-02-2012, 14:56
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Victor reversed wiring...
The only thing that should happen when you reverse the polarity of the wires is the motor spinning backwards.
Unread 13-02-2012, 15:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Read his post again:
Unread 13-02-2012, 15:04
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Mark,
You are extremely lucky. If this was me, I would be ordering some Victors as replacements. There is no protection built in. What is working today has been stressed to the point of near failure and will likely take a hike in the future.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 13-02-2012, 16:40
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
Rookie Year: 2000
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
I expect there is back EMF protection built into the controllers which protects the controller when you cease applying power to a motor and the motor turns into a generator, backfeeding into the controller. If the controller was in brake mode it would have shorted the connection and could have damaged the brake mode functionality of the controller. Otherwise I would expect them to be equipped with some sort of supressors or diodes which (bearing in mind I have no clue how they are wired) could have fed back to the power input terminals? I would tend to think if the controllers work fine and they don't smell like magic smoke, you should be fine. I have seen many teams pushing their robots around while powered down and have watched various lights light up and fans spin from the current being generated and fed backwards through the controllers by the spinning motors.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 13-02-2012, 17:23
Unsung FIRST Hero
Rookie Year: 1996
fox,
There is no protection. What you have observed (and what takes place during brake mode) is that the diodes that are a result of manufacturing in MOSFETs will conduct energy from the motors to the power supply or to a short with multiple FETs turned on. When power is supplied to the controller output, reverse currents may flow in the interface electronics and the microproc on board the controller. Many teams have reported controller failures as a result of this very same mistake just this year.
Al
WB9UVJ
www.wildstang.org
Unread 13-02-2012, 17:29
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
You may also notice that spontaneous electrical failures tend to happen in clusters. Some teams have had countless motor controller failures, where other teams haven't had any. The "unlucky" teams are abusing their electronics, whether it is by metal shavings, pushing their robot around unpowered, or other, and they don't realize it because the damage doesn't immediately show itself.
I don't want to sound alarmist, but you have to accept that you have caused some amount of damage to these parts. Have spares ready.
Unread 13-02-2012, 18:42
fox46's Avatar
Rookie Year: 2000
No disrespect to your expertise Al and I don't pretend to be an expert on any of this but there must be *some* sort of protection- (a "tolerance" would likely be more appropriate) for backfeeding power. Every time you cut power and the motors are spinning down they are applying power to those terminals so there must be some sort of suppression. How much "reverse" power the controllers can handle is anybody's guess but watching kit robots "skate" in coast mode and get pushed around even in brake mode would suggest to me it is at least enough to tolerate it for a little bit. Sure- extensive "pushing around" a robot would certainly damage something but the big question is how much before this happens?
In 2000 when I was in grade 10, our school used to participate in the now defunct "Canada First" robotics competition- brainchild of the late Bruce MacMillan, a spinoff of FIRST before the GTR regional came into existence. That particular year the competition organizers had designed a custom control board that when interfaced with an RC aircraft system provided control to the robots. Unfortunately the system was plagued with problems in the form of exploding MOSFETs/Transistors and the on-board microprocessor. The cause was a poor design where the designer had overlooked this kind of protection. Voltages which backfed to the controller when the power was turned off (so we were told) was causing the processor to cook itself- just like you describe. The motors we were supplied with were windshield wiper motors with very little "spindown" and were virtually impossible to backdrive which meant only a very small amount of power was needed to cause this condition. This is why I am convinced the Victors and Jags have at least some tolerance to reverse voltages otherwise I am confident they too would cook. The solution to these issues that was implemented AT the competition was replacing all the power switching hardware on the boards with relays resulting in only "ON/OFF/ON" control.
Unread 13-02-2012, 18:50
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Hooking a battery up would be far worse then extensive "pushing around".
Unread 13-02-2012, 19:17
fox46's Avatar
Rookie Year: 2000
And yet....
Unread 13-02-2012, 20:25
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Well if you're hooking up the battery where the motor goes then the current will flow through the motor (and possible backwards to the controllers) if one of the mosfets from the top and the opposite from the bottom is on. If both bottom or both top mosfets are on, such as in brake mode, then you'd be shorting out the battery.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 15-02-2012, 08:02
Unsung FIRST Hero
Rookie Year: 1996
Fox,
Unfortunately the answer is NO, there is nothing in the way of backward protection. The FETs have a diode that is across the terminals that results from the manufacturing process. If you look at the spec sheet you can see the diode and the direction in which it conducts. The four legs of the "H" bridge do conduct as a full wave bridge and provide power of the correct polarity at a reduced voltage backwards to the power rails of the controller. These diodes do have a forward voltage drop though, so the conducted voltage isn't quite what you would think. Remember that when the controllers are powered correctly, and a 'coast' condition is commanded, all of the FETs are off and current only flows through the diodes (the same is true for pushing with power off). When a 'brake' is commanded both low side legs of the controller are turned 'on' resulting in a short across the motor but no power being delivered to the controller internals and no current flowing through the diodes. In the case of the power leads being attached to the output terminals, we don't know if they were wired in a normal polarity. In any case, considerable current may flow through the controller restricted only by the breaker feeding the device. Depending on the duration (or repeated attempts to determine the cause) significant damage to the device might be the result. Magic smoke is almost always the result.
Al
WB9UVJ
www.wildstang.org
Unread 13-02-2012, 18:30
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
Oh sorry I misunderstood what he meant.
