Go to Post What really matters is what you got out of the FIRST season, and how you can use it to build on what you know. - Adam Richards [more]
Unread 13-02-2012, 15:48
Waltonruler5 Waltonruler5 is offline
FRC #1591
Waltonruler5 is an unknown quantity at this point
Spike Relays won't recognize values
I'm trying to program two intake motors for our feed system using spike relays. I'm using the command template shown by BradAMiller. I defined each motor as a spike and mapped it to the proper channel. I create the method intakeOn and go to set the value but it tells me there's an error. I type
intakeMotor1.set(Relay.kForward);
and it tells me that the symbol "kForward" is not found in the class.
I programmed another subsystem to use the spikes without difficulty but we switched them to victors so I can't look back at the code.
