Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 13-02-2012, 16:01
andreboos andreboos is offline
FRC #3021 (The Agency)
Rookie Year: 2010
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Voltage divider
What is a safe way to divide voltage on an FRC robot?
I'd like a relay to drive a motor at far less than 12 volts. According to the wikipedia page, the voltage of a resistive voltage divider would vary with the load, and I'd like to keep it stable. Additionally, the resistors would have to be rated for multiple hundreds of watts to be FRC legal, and those that I can find are expensive and bulky.
Edit: Does R47 prohibit resistive loads between a relay module and a motor?
