Go to Post "FIRST is like a pizza, we all think different toppings should be on it" - Andrew Schreiber [more]
Unread 14-02-2012, 17:15
Team 4264 Team 4264 is offline
FRC #4264
Team 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud ofTeam 4264 has much to be proud of
Reversed Polarity
Someone screwed the battery cables on backwards and then installed that battery. The power brick started clicking wildly, and then turned it off. Once we figured out what had happened and switched the cables, many of the lights don't work.3 JAgs no lights, 1 with yellow, Crio lights=yes, sidecar lights=yes orange lights on fuse boxes, and fuses are ok. Is it fried or is there a hidden reset? Please reply in rookie speak. =)
Thanks
Unread 14-02-2012, 17:25
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Reversed Polarity
The good news is that your PD, cRIO, and DSC (sidecar) are all fine.
The bad news is that your Jaguars are all fried. You will need to replace them.
Unread 14-02-2012, 17:26
FRC #4264
OMG!
Even the one with the yellow light?
Unread 14-02-2012, 17:30
Rookie Year: 2000
The one with the yellow light may continue to work for some amount of time, but you should consider it to be damaged and likely to fail soon. It might be workable for a practice robot, but I would not trust it in competition.
Unread 14-02-2012, 17:49
FRC #4264
Is there a part inside the Jags that can be replaced? $400 replacement blows our budget and Andymark is out of them.
Unread 14-02-2012, 17:57
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Thanks
We did this a few years ago. We fried 3 jags ... and the 4th jag survived just fine. It's a risk to use that jag in competition, and you'll have to decide if it's worth the risk.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 14-02-2012, 18:05
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The damage internally will be severe (blown FETs and most likey other components).
Digi-key has them, and you should have a digikey voucher for $50 in the KOP. Sorry man, thats what happends.
___________________
- Tennyson, Ulysses
Unread 14-02-2012, 18:13
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Digikey doesn't have them at the moment, actually. They seem to be out of stock. Along with the rest of the world.
As Daniel says, you're going to be fighting quite an uphill battle trying to repair those. I think you have two options:
1. Beg, borrow, or buy any black or grey jaguars off of teams that are near you.
2. Switch to VexPro Victor 884 Speed Controllers. There's loads of teams that swear by them anyways, and they're $10 cheaper than Jags. If you're not using the advanced functionality of the Jaguars, these will work atleast as well for you.
Unread 14-02-2012, 18:25
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Where can Victors be bought for $75?
Unread 14-02-2012, 18:30
Ether's Avatar
Rookie Year: 1969
Your team (or leaders) should sit down and figure out how that happened (not to place blame, but to understand), and figure out if there is something you can do to prevent it from happening again (both this year and in the years to come).
Different teams come up with different solutions. Find something that works for your team.
Unread 14-02-2012, 19:33
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
CD swap shows someone with victors offering them to us. check him out. No jaguars listed, but you could enter a NEED for them if you like. I don't know if we have unused ones in our chaotic "storehouse".
I second the need for determining how to prevent reverse polarity disasters by figuring out how it happened. It's an uphill struggle to convince the team members that I'm not seeking a blame target. It's been rare or absent in their lives so far.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 14-02-2012, 21:58
Rookie Year: 1998
Where can you get a Black Jaguar for $85? Vex is selling Victors for $89. I was comparing to the AM discounted Jaguar Bundle price of $99. Digikey will sell them to you for $109, though you do get a $50 voucher at Digikey. That's pretty much the price at Mouser, Avnet, Newark, and TI itself. None of whom have stock, so you can't have a Jaguar at any price anyways, but still.
TI says Rochester Electronics has 50 Jaguars in stock, and Rochester lists some if you search for "MDL-BDC24", but I'll be darned if I know how you order some from them.
Unread 14-02-2012, 22:20
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Digikey sells them to FIRST teams at a special discount.
$85
Don't pay list price.
Unread 14-02-2012, 22:22
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The first discount at digikey Is $85.
Go here
Should work even if you have used your $50.00 coupon. But they are not showing stock
  #15   Spotlight this post!
Unread 14-02-2012, 22:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
DigiKey is supposed to be selling Jaguars to FIRST teams for $85. I think that's what we payed for ours.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
