Go to Post Hey that was easy, we settled the argument on CD in one post! :^) - KenWittlief [more]
Unread 14-02-2012, 17:39
Doc543's Avatar
Doc543 Doc543 is offline
Electrical, Pneumatics, Driver
AKA: Eric
FRC #1891 (BullBots)
Doc543 is an unknown quantity at this point
Reset Jags through CAN with Java
is there a way to reset the CAN Bus in Java? On our prototype some of the Jags would stop outputting voltage sometimes especially when the battery is low, restarting the Bus always fixed the problem.
The only way i can think doing it is the .disableControl(); and then .enableControl(); but that is only on one Jaguar
any thoughts?
"Its just a prototype."
2011 Chairman's Award Utah Regional
2010 Gracious Perfectionism Utah Regional
2009 Gracious Perfectionism Portland Regional
Unread 14-02-2012, 18:10
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Reset Jags through CAN with Java
When you say you were "restarting the bus" on your prototype what does this mean? Were you using a different language? Or some other control device?
Unread 14-02-2012, 21:13
Doc543's Avatar
AKA: Eric
I was using the BBC-COMM Jaguar test program. It has a reset button that will reset the bus.
