Go to Post We are here to educate, inspire, and mentor not only the students, but teams who need guidance, whether they know it or not. - Andy Baker [more]
Unread 02-14-2012, 06:12 PM
Cody Trey's Avatar
Cody Trey Cody Trey is offline
Programing = hard + fun
FRC #2582 (Panther Bots)
Cody Trey is an unknown quantity at this point
Send a message via Yahoo to Cody Trey
Mecanum not driving backwards correctly
When we try to drive backwards slowly the robot tries to turn as if it has a jag calibration problem, but we've calebrated many times, it doesn't do this in any other direction. We've gone so far to replace jags and sidecar. Does any one have a clue as to why this might be happening?
Much thanks
Cody Belcher
Programer
Love, Peace, and Robot Grease
Unread 02-14-2012, 09:00 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Mecanum not driving backwards correctly
One of your motors might have more directional bias than the others, or it could be a mechanical issue with one of the gearboxes. Put the robot up on blocks and run each motor individually at the same low power, and see if one of them turns more slowly.
Unread 02-15-2012, 12:25 AM
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
It could be a mechanical issue you won't see on blocks, even. Remember that mecanum wheels have significant sideload when you're driving straight. One of your wheels might be getting shoved into something or you might be putting extra load on a questionable bearing when you're driving backwards.
