Go to Post A year where the students learn a lot and win nothing is more rewarding than a year where the team does well and doesn't learn much. - Molten [more]
Unread 14-02-2012, 20:38
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Splicing Signal Cables
Is it possible to splice signal cables together on servos, and have them draw their power directly from the power distribution board? And more importantly, is this legal?
Also, how many wires do you think can be spliced (talking about PWM cables) together before there is to much signal loss?
"Don't worry, programming can fix it"
Unread 14-02-2012, 20:53
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Splicing Signal Cables
Servos drawing power from the PDB, in general... well, that's pretty complex in terms of possibility. You'd have to keep all the servo wires inside the PDB's Wago connectors, which they're too small for individually. And, you run right up against [R42-D] requiring only one wire per Wago port, along with [R50-B], which requires servos to run into the PDB.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Last edited by EricH : 14-02-2012 at 20:54. Reason: Wrote a section in anger, so deleted it.
Unread 14-02-2012, 20:57
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
Why? Are you out of PWM outputs on the digital sidecar? If so you can add a second digital sidecar.
Prototype, Prototype, Prototype
Unread 14-02-2012, 21:09
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Servos draw 6v of power from the Digital Sidecar.
The Power Distribution Panel supplies 12v for most things (plus 24v for cRIO and Solenoid Breakout, and 5v for camera.
Unread 14-02-2012, 21:22
Trez's Avatar
FRC #3606
So that would fry a servo, right?
Unread 14-02-2012, 22:41
AKA: Bobby
ok, thank you everyone, the intention was because I was running out of ports on the DSC, and I had temporarily forgotten that you can have a second DSC. Thank you everyone.
