Go to Post This isn't about practical, it's about having fun and thinking outside the box... tetrahedron.... whatever....:rolleyes: - Cyberguy34000 [more]
Unread 14-02-2012, 21:22
badger3.14's Avatar
badger3.14 badger3.14 is offline
AKA: Hayden
FRC #2512 (Duluth East Daredevils)
badger3.14 is an unknown quantity at this point
encoder jumping between two values. please help!
On our robot, we are trying to use the 360 clicks per revolution encoders from us digital to regulate our speed for our shooter, but when powering up the wheels and reading the values in labview, the encoders read steadily until 20833.3 clicks per second. When going above that, the values jump from 20833.3 to 41666.7 clicks per second.
Any thoughts or answers???
Unread 14-02-2012, 21:38
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: encoder jumping between two values. please help!
You may be exceeding the capabilities of either the encoder or the cRio. Research the limitations of both with regard to data rates for the DI/O and the encoder you have chosen. Reading over 20000+ samples a second is significant overkill. Consider getting a different encoder wheel to tone that down to 100, 32, or even 16.
Unread 14-02-2012, 21:46
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
The counting circuits in the FPGA are only good to 40000 counts per sec. How fast is your wheel turning? You had better use the k1X setting. We are going with 32 cpr encoders for this reason.
Fast, cheap or working - pick any two!
Unread 15-02-2012, 18:32
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Just had the same problem today. Got it fixed. The problem is the Decoding rate (at least that's what it's labeled as in LabView). If it is set to 4x the variation is huge, at 2x its smaller, and at 1x its almost nothing. Talk to the programmer and see what it's set to.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 15-02-2012, 19:30
badger3.14's Avatar
AKA: Hayden
thanks for the input, our team ordered two new 32cpr encoders today. i am hoping that this will fix the problem.
