Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 15-02-2012, 08:42
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
Compressor and 2-can
after many, many hours of chasing what seems like wiring problems, we believe we have identified a problem with the compressor while running 2-can. we can work the compressor just fine without drive code, and can run our Jaguars off 2-can without the compressor. to get the compressor going, we enabled the disable code block in periodic tasks.
when we have both, the compressor's behavior is erratic. sometimes it works, sometimes is runs for about 1 execution cycle and sometimes it doesn't run at all. we are getting errors on the driver's station saying something like robot drive loop not getting inputs, etc, something that makes me think either the compressor or the 2-can is using all the processor.
we have changed out cables, side cars, crio modules, spikes, just about everything.
we are using the 2-can module purchased from cross the road electronics.
has anyone else seem this? is anyone running 2-can and the compressor successfully? is there a switch setting on the crio we need to change?
http://www.team1912.com
2013, 2012, 2011, 2010 Regional Chairman's Award, Bayou Regional
2013 Woodie Flower's Award, Bayou Regional
2012 Dean's List Winner (Rachel Holladay)
2015, 2014, 2013, 2012, 2011, 2010 Beta Test Labview/Hardware
2012, 2011 Best Website, Bayou Regional
2011, 2009, 2006 Gracious Professionalism
2007 Bayou Regional Winner
