Go to Post Its just going to be a dirt game. We are going to be using shovel bots to dig for gold. Anyone who strikes oil gets the 100 point bonus! - Uberbots [more]
Unread 02-15-2012, 10:16 AM
Gatlin18 Gatlin18 is offline
FRC #2373 (Crickets)
Rookie Year: 2010
Gatlin18 is an unknown quantity at this point
Not showing Battery Voltage
When we turn our robot on, connect, and start to run it, it works perfectly. But, the voltage of any battery we connect stays at 0.00. No idea what is the problem. Any ideas?
Unread 02-15-2012, 10:22 AM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Not showing Battery Voltage
No idea what you've done or tried.
Did you put the battery jumper on the Analog Breakout in cRIO slot 1?
Did you power the Analog Breakout from a 12v on the Power Distribution Panel?
Unread 02-15-2012, 11:02 AM
Rookie Year: 2010
I had a different connector than that. I just put that one in, and I am not looking for the jumper to try it. Thanks.
Unread 02-15-2012, 08:38 PM
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
It's most likely the jumper is not in the correct spot, or not at all. However we did have a rookie team that had the same problem even with the jumper installed, turned out to be a bent pin in the underneath the analog module on the crio. So be aware of that.
Unread 02-17-2012, 08:23 AM
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Yeah if that jumper is in the right place and the analog module is powered, you should be able to see the battery voltage in the driver station and the dashboard if you have that programmed in.
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 02-19-2012, 02:32 PM
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
What do you mean Programmed in?
Unread 02-19-2012, 02:43 PM
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
It's not in code that you should be modifying, IIRC. It should be a case of plug the jumper in and open the proper tab in the driver's station, and you'll see your battery voltage.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
