Go to Post I guess instead of focusing on the stuff we wish we could have changed, we should focus on all of the wonderful stuff we accomplished instead! - Winged Wonder [more]
Unread 15-02-2012, 17:13
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Rookie Year: 2010
Itamar is an unknown quantity at this point
Jaguar stops powering the motor after a few seconds
Hey,
We have a Jaguar connected to a cim motor with a transmission we made and to a sidecar module via PWM. The motor moves two axis. When we run it at any speed it works for a few seconds (not at constant intervals), stop, and after a few seconds starts working again.
We looked at the Jaguar's LED. When the motor is running the LED shows red value and when the motor stops it changes to yellow. We tried replacing a Jaguar and a PWM, but the problem persists.
I don't believe this is a software problem. I work with LabVIEW, and the code to power this Jaguar is very simple. Just in case, I called the "GetOutput" VI and the value is the same as sent, as expected. It never changes to zero, even when the Jaguar stops powering the motor.
We double-checked, the battery has over 12V.
What can cause this weird behaviour?
Thanks in advance,
Itamar.
Unread 15-02-2012, 18:25
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Jaguar stops powering the motor after a few seconds
Is there any sort of clicking noise coming from the PDB when the motor stops running? If so, something (namely, too high current for too long) is probably causing the circuit breaker to trip.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-02-2012, 18:35
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
Hey Eric, we checked and there were no clicks coming from the PDB. However, we discovered that the problem occours only when we make it go from 0 to high values. If we start the motor at 0% speed and gradually and slowly raise it to 100%, it works fine and doesn't stop.
Unread 15-02-2012, 18:43
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Sounds like the Jaguar is getting an over-current fault.
Generally, traceable to the CIM gearing and a too-resistant object being moved making the CIM hard to get going.
Jags don't like to draw CIM stall current for very long.
Unread 15-02-2012, 18:48
Trez's Avatar
Trez Trez is offline
FRC #3606
Trez is an unknown quantity at this point
My team had a CIM problem where the two screws that hold the motor in to something, were in too far. The motor would work for a few seconds then stop.
Prototype, Prototype, Prototype
Unread 15-02-2012, 18:51
FRC #1943
Generally, traceable to the CIM gearing making the CIM hard to get going.
I am pretty sure you are correct. We have activated the motor directly with a battery and it ran okay for a few minutes. Is it possible to prevent the over-current fault? Does the Jaguar stop to protect the motor or itself?
Unread 15-02-2012, 18:59
Just Itinerant
The Jaguar is protecting itself from the over-current.
A CIM is pretty robust and will handle it much better. It pulls 133 amps at stall.
One way around the problem is to ramp the Jag in software.
Not always successful because the Jag gets increasingly sensitive to over-current the warmer it gets, so the ramp may have to get gentler over time.
A better way is to regear the CIM gear/sprocket train, but that's not always practical.
A third way is to switch to a Victor in this particular application, because it's a bit more forgiving, but the Victor won't protect itself, so there's a chance of burning it out.
Unread 15-02-2012, 19:09
FRC #1943
One way around the problem is to ramp the Jab in software.
When you say "ramp the Jab in software", do you mean to start at 0% and gradually raise the value?
Unread 15-02-2012, 19:13
Just Itinerant
Yes, the same sort of ramping or coaxing along you were doing manually to get it working. Just do it in software set to ramp up the power more slowly.
Be conservative when you do it, don't try to push the Jaguar as fast as you can. Give it some breathing room.
Unread 15-02-2012, 19:21
FRC #1943
That's what I thought. thank you!
Unread 17-02-2012, 10:24
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Add a slew-rate limiter.
For LabVIEW, see this article:
http://thinktank.wpi.edu/article/140
For C++ or Java, see here for some pseudo-code:
http://www.chiefdelphi.com/forums/sh...23&postcount=2
Unread 15-02-2012, 19:01
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The Jaguar is protecting itself and the robot from excessive current draw.
Take a look at the 2012 Jaguar FAQ. Specifically Q20.
-David
Unread 17-02-2012, 01:43
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
Rookie Year: 2012
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
We (rookie team) had a similar problem during code testing. We added an acceleration ramp and that helped but the JAG was still unreliable. We almost ordered a replacement, but first tried a factory reset. It's been working perfect ever since.
