Go to Post Holonomic? I thought we were holographic. Or was that autonomic? I'm confused.... - Wayne C. [more]
Unread 15-02-2012, 17:24
flippy147852's Avatar
flippy147852 flippy147852 is offline
respect the hat
AKA: Felipe Agurto
FRC #1918 (NC GEARS)
flippy147852 is an unknown quantity at this point
Robot code delay on startup
When we first enable the robot after startup, there is a five to ten second delay before we can operate the robot. We have no errors or extra code that would cause this, so if anyone knows whether this should happen or how to fix it, please let us know. Thanks!
NC GEARS = Newaygo County Geeks Engineering Awesome Robotics Solutions
2009: 5 Events, 60-25-2. 1 District Win, 3 Finalists
2010: 4 Events, 51-13-6. 1 District Win, 1 Regional Win, 1 Finalist
2011: 4 Events, 58-18-4. 2 District Wins
2012: 4 Events, 46-25-0. 1 District Win, 1 Finalist
Total: 17 Events, 215-81-12. 308 matches in 4 years
Scouting it all: Priceless
Unread 15-02-2012, 17:39
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Robot code delay on startup
I'm experiencing this as well with a brand new 4-Slot cRIO.
Unread 15-02-2012, 21:05
I've seen this happen when Begin was allocating a number of things that fail out --serial and camera can both contribute.
One thing I often do is to put a small wire from the i terminal to the edge of the loop. For teleop, that turns into a feedback with a +1. Then I can probe some of these spots and see which loops are running, which are not, and get a sense of performance. A step up from this in terms of info is to use the Elapsed Times VI in the Support folder. You place this wherever you like and open the Elapsed Times to see the rate info.
This should help narrow down which code is responsible.
Greg Mckaskle
