Go to Post There is no offseason. - Jeff Rodriguez [more]
Unread 15-02-2012, 18:35
cddp14 cddp14 is offline
FRC #1270
cddp14 is an unknown quantity at this point
Can't deploy code to cRio using WindRiver
For the last 5 weeks I have had no problems deploying code to my robot until last night. When I go to FIRST-> Deploy the download window opens up and it starts to download my code but then the window suddenly closes. There are no errors reported. I have the the correct .out file selected. I have reimaged the cRio and restarted both the computer and the cRio. I have also pinged my cRio with the command prompted and it responds. I have tried Target -> New Connection and it comes back with errors but honestly I don't what this is for.
Here are the errors: Error: loading core symbol table: status = 0xe0004
Error: Unable to load /c/ni-rt/system/vxWorks
Error: Unable to load the kernel image into the target server.
I don't know what else to do. Please Help!!!
Unread 17-01-2013, 17:23
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: Can't deploy code to cRio using WindRiver
The problem described here is a symptom of incorrect target server option specification.
You need to be sure you specify the proper kernel image file and the proper processor, when creating the target server.
For 2013, this is well covered in the "Configuring WindRiver Workbench" section of WPI's Getting Started with C++.
Check out http://wpilib.screenstepslive.com/s/...iver-workbench for the target server info section.
Team 3765 was getting this error initially, and the error went away after the proper kernel image file was referenced in the target server creation.
