Go to Post Great. Just what we need. DHS showing up at all the regional competitions. . - dlavery [more]
Unread 15-02-2012, 23:04
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Is This Happening to anyone else? (C++)
Hey,
Right now we are running into an issue with the six jaguars and one victor we are using. When we have our 4 drive jags set up (as either separate objects or as part of a RobotDrive Object), it behaves normally. When we have our shooter (2 jags and 1 victor) set up - without the drive jags - it behaves normally. The second we let them play together, things start exploding - aka we can't drive ANYTHING. I'm able to print values to the DS via DriverStationLCD, but it seems those values have no effect when I tell them to do things with (ObjectName).Set().
Even INITIALIZING them causes this issue; I didn't even give the drive jags values to run with and it stopped working. Tried two different computers, one with the complicated (i.e. Main) code and mine with a stupid simple test setup.
A: Any Ideas?
B: Any one else running into this?
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 16-02-2012, 03:07
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Is This Happening to anyone else? (C++)
Are you sure you are using unique PWM channels for each controller? We have 2 jags, 8 victors and 6 spikes playing well together.
Fast, cheap or working - pick any two!
Unread 16-02-2012, 11:25
Zuelu562's Avatar
AKA: Jake Janssens
It's actually one of the very first things we checked. For reference, one of the other mentors on my team e-chatted with a guy from the WPILib team and said it might have to do with us not powering the sidecar (which we aren't...whoops).
Team Resume
Volunteer Resume:
Unread 16-02-2012, 11:36
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Good catch - that will kill you every time!
Good luck this year!
