3647 up and runnning
http://www.youtube.com/watch?v=yfgZo...3JCQRh4SPI7mI_
http://www.youtube.com/watch?v=Pd2_E...3JCQRh4SPI7mI_ 10inch pneumatic tires from skywaywheels and AM Toughbox Minis. The last bit was caused when a bearing fell out of the gearbox, causing the small cluster to drop into the gearbox... Shooter and the bridge lowering mechanism isn't attached in this video. |
Re: 3647 up and runnning
Nice robot! The rollers are very sleek.
If I may ask, what is the total reduction on the motor driving the rollers? (gearbox and pulley). It looks like a 550 with a 16:1 gearbox, but I cant guesstimate the pulley sizes. I asked because we have 550's with 4:1 gearboxes and plan to use them, but we are afraid of them being undertorqued. It seems like yours is working fine, so we may want to try that reduction out. |
Very nice robot 3647! Those wheels are awesome! |
Our design uses 2 550's with 4:1, so I was wondering if you were having trouble when using 2 motors geared together, or just 1?
For the tower the gearboxes are 16:1 P60s with 550s then pulleys are 5inches [off mcmaster] to the PVC which is about 3inches in diameter. The original design called for 3inch pulleys for a 1:1 but a mistake with our McMaster order caused use to get 5 inch ones...
We have had no issue with toque; as you can see they fire up instantly. Lots more photos in our blog linked my sig. |
