Go to Post If only 5% of American entry level workers are proficient in algebra in 2022, I'm moving to Canada. - PVCpirate [more]
Unread 16-02-2012, 05:23
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
Rookie Year: 2012
DavisDad will become famous soon enoughDavisDad will become famous soon enough
How many rules does this catapult design break? :)
Prototype @ 35' : http://simhardware.org//img/FirstTry.avi
Slow Motion Study:http://simhardware.org//img/Compound...-2_slow-mo.MP4
Unread 16-02-2012, 07:40
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: How many rules does this catapult design break? :)
Hard to answer the question without seeing how it's mounted on the robot, but as a device, it looks effective and legal.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 16-02-2012, 08:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Dad,
Is that part of a compound bow with camo that I see? If so, I would want to know how you modified it for this mechanism. I can't tell much from the picture but my first response is usually one of safety and the possibility of this mechanism self destructing in firing. Is the material a laminate and is it capable of a dry fire without damage? I might have a UL safety person check this out during inspection if I was your inspector.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-02-2012, 08:45
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by DavisDad View Post
The only issue I see with this design is safety during transport onto the field with the robot powered. You'd need either no energy stored in the catapult arm or a safety lockout (pin?).
Other than that, its a wonderful out-of-the-box type launcher.
Are y'all going to be at GSR?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 16-02-2012, 08:58
DavisDad's Avatar
MechE
Rookie Year: 2012
Roger that on the safety. I've copied the Mathews mount ("limb pocket"), prestress and string angles as closely as possible. The cylinder (this one is temporary, final will be 1-1/2 bore, 6" stroke) adds a load to string to string during a dry-fire. I think the most likely failure mode would be pieces flying of the pivot arm.
Thank you all for the feedback. This may be a secondary launcher to our already developed spinning wheel shooter. If weight allows.
Unread 16-02-2012, 09:02
Unsung FIRST Hero
Rookie Year: 1996
Glad to hear you are thinking about that usage in the design.
Al
WB9UVJ
www.wildstang.org
Unread 17-02-2012, 09:13
Unsung FIRST Hero
Rookie Year: 1996
Dad,
I did a search and it appears that the parts you are using required no machining on your part, is that correct? More or less just a bolt on?
Al
WB9UVJ
www.wildstang.org
Unread 17-02-2012, 11:26
DavisDad's Avatar
MechE
Rookie Year: 2012
Originally Posted by Al Skierkiewicz View Post
Dad,
Hi Al,
Thanks so much for the thoughtful response. As a newbie mentor, your help is greatly appreciated.
The only parts that I made, that touch the composite bow limbs, are the "limb pockets" parts:
  1. Delrin guide/spacer for adjustible tension
  2. Ball socket (1/2 sphere washer) for bolt pivot point
If the shooter works well I may order OEM parts to eliminate doubt about the limb restraints.
I have been scrambling to get developed enough to test accuracy. If the performance pans out, I intend to make shop drawings and write up my analysis for review. Sorry I don't have this ready now...
Unread 17-02-2012, 14:10
372 lives on 372 lives on is offline
FRC #0372 (Robo-Knights)
Team Role: Mascot
372 lives on has a spectacular aura about372 lives on has a spectacular aura about372 lives on has a spectacular aura about
how about
[R14]
No individual item shall have a value that exceeds $400.00. The total cost of Components purchased in bulk may exceed $400.00 USD as long as the cost of an individual Component does not exceed $400.00.
last time I checked the bow this came from cost around $900...
cole?
Unread 17-02-2012, 14:43
teh_lol's Avatar
teh_lol teh_lol is offline
FRC #0486 (Panther Robotics)
Team Role: Driver
teh_lol is an unknown quantity at this point
Originally Posted by 372 lives on View Post
how about
[R14]
You can buy just the limbs for a bow depending on the company that makes it and the piece that is taken.
Unread 17-02-2012, 15:27
DavisDad's Avatar
MechE
Rookie Year: 2012
how about
[R14]
No individual item shall have a value that exceeds $400.00...
...last time I checked the bow this came from cost around $900...
I paid $40 at Reedy's Archery shop (Middleboro, MA) for a used set. The guy gave me a discount when I told him about our robot competition. He said he could get $80 used. I assume they cost about 2x that. I couldn't find a price on-line for the limbs new.
Unread 22-02-2012, 05:48
DavisDad's Avatar
MechE
Rookie Year: 2012
My son and I tested the latest version of the “compound catapult” yesterday; properly sized cylinder and trigger release (couldn’t exhaust air fast enough}. We hit 6/6 @ 27.5’ (video below) until part failure. We were setting range by adjusting pressure until bow limb deflection was the same as measured by a caliper. We were cocking to about 75% of max force. We are working on the load beam/pressure transducer feedback cocking mechanism…
http://simhardware.org//img/Compound...atics30fps.MP4
http://simhardware.org//img/Compound...tics240fps.MP4
Unread 14-01-2013, 04:26
kclark kclark is offline
kclark is an unknown quantity at this point
I'm planning on making a smaller one of these for a project for college, where did you get the air cylinder from?
Unread 14-01-2013, 18:35
DavisDad's Avatar
MechE
Rookie Year: 2012
http://www.bimba.com
You can buy direct from the "Buy Online" page.
Have fun!
