Go to Post I say: Chutes & Ladders in FRC 2008! - petek [more]
Unread 02-16-2012, 11:13 AM
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
Team Role: Coach
rudun is an unknown quantity at this point
Netbeans Console goes blank
As we are printing statements to the Netbeans console it will suddenly go blank and have to be restarted in order for us to read the output again. Is anyone else having this issue?
Unread 02-17-2012, 08:28 AM
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Re: Netbeans Console goes blank
We had a problem once where we would just stop getting output from the robot once the robot code started running. The rest of the output stayed there, but we would just get no more output at all. Is that the problem you're describing? Our solution was just to switch to Eclipse .
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 02-17-2012, 10:45 AM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
If the robot is still sending the output, it can be read by several different programs, even all at the same time.
  • On you driver station, click Start>>All Programs>>NetConsole for cRIO.
  • OR On your developer machine:
    Open a terminal window
    Change the directory to your robot project's dir.
    Type "ant echo" - this should duplicate what NetBeans does.
