Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
  #16   Spotlight this post!
Unread 16-02-2012, 12:46
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: TOP HEAVY!!!!
Are you doing a one wheel or a two wheel shooter? If it's a one wheel shooter, the easiest thing you could do is remove one of the CIM motors from the shooter. The shooter's top speed would be the same, although it would take longer to spin up to its top speed.
Edit: if it is a two wheel shooter, you can probably put a sheet of something behind one wheel and convert it to a one wheel shooter.
Depending on what the robot looks like, it might be feasable to lower the entire shooter before you bag. I know we have mentioned it, since our wide configuration robot is tippy and it wouldn't be that hard to shorten our conveyor. That would sacrifice some shooting height to gain stability, which could potentially be a good trade.
  #17   Spotlight this post!
Unread 16-02-2012, 12:55
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: TOP HEAVY!!!!
I would also added the bumpers for the simple fact that you are adding mass to the base of the bot, therefore, lowering the CG.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
  #18   Spotlight this post!
Unread 16-02-2012, 13:02
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: TOP HEAVY!!!!
Get some 775s or 550s and CIM-U-LATOR gearboxes and drop several pounds per motor up top. Add the CIMs back to the drive train down low.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #19   Spotlight this post!
Unread 16-02-2012, 13:11
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
Rookie Year: 2011
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: TOP HEAVY!!!!
Originally Posted by DonRotolo View Post
Shaun,
This is a rookie year for you guys, right?
OK, this kind kind of thing is what someone needs to write down so that next year's team knows it. One lesson is that the electronics guys need some space, the mechanical guys need to understand that (because high-up electronics have a tendency to get hurt, and high-up weight is always bad).
Please see if you can take a photo and post it so we can offer reasonable suggestions that will work in the time we have left.
One last thing: Congratulations! Not many rookie teams have a working robot already.
Absolutely agree here. Just look up the equations for angular momentum and kinetic energy of rotation and you will see why a tall robot may not behave well. Reducing the height (if you can) will pay back large dividends in stability. It is really difficult to increase the weight of your base by 25% late in the build and not go over weight. But decreasing the height the same amount is often quite possible, and may not even be that difficult.
This is the zeroth day of the rest of your life.
  #20   Spotlight this post!
Unread 16-02-2012, 13:18
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: TOP HEAVY!!!!
I guess I should have posted a link about 5 weeks ago...sorry!
http://www.chiefdelphi.com/media/papers/1974
  #21   Spotlight this post!
Unread 16-02-2012, 13:20
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: TOP HEAVY!!!!
Lots of good suggestions so far. One thing that hasn't been mentioned, probably because it isn't a great solution, is that a robot with low-friction wheels (e.g. omni wheels) will slide instead of tipping. Not great, but if all else fails, it's something to try.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #22   Spotlight this post!
Unread 16-02-2012, 15:44
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: TOP HEAVY!!!!
Originally Posted by JamesCH95 View Post
Get some 775s or 550s and CIM-U-LATOR gearboxes and drop several pounds per motor up top...
(emphasis added)
CIM == 2.8 lb each
775 == 0.75 lb each
CIM-U-LATOR == 0.5 lb each
Total weight savings == 3.1 lb (top only)
If you add the CIM's to the bottom, it's a net gain of 2.5 lb. Is that in your weight budget?
If you can (I know it's late in build season), shortening the robot as others have suggested can be a big improvement. CoG goes down, angular momentum goes down, stability goes up. Our team did this, and we believe the advantages outweigh the disadvantages.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Last edited by Cal578 : 16-02-2012 at 15:45. Reason: math correction (because you need 2 gearboxes)
  #23   Spotlight this post!
Unread 16-02-2012, 18:33
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: TOP HEAVY!!!!
Get rid of your 80/20 "camera mount" up top including the uprights, leave the shooter support.
Replace with some of that wonderful lexan you got accidentally.
Look to relocate the battery in the center behind your lift mechanism, instead of at the back of the robot.
Also, consider moving the transmissions and motors forward, in between the front two wheels (instead of the back).
I'm currently looking at small pictures on my phone . . have you guys actually gotten the scale to weigh it yet?
The bumpers will help your top bottom a bit, but you NEED to fix the fore/aft problem.
  #24   Spotlight this post!
Unread 16-02-2012, 19:18
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: TOP HEAVY!!!!
I posted about Team 4's "Tip-proof" robot in CD a few years ago.
It has an educational and entertaining YouTube clip showing what you can do with a very low CG.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
  #25   Spotlight this post!
Unread 16-02-2012, 20:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: TOP HEAVY!!!!
Originally Posted by Cal578 View Post
(emphasis added)
CIM == 2.8 lb each
775 == 0.75 lb each
You're right, it's just a few pounds for both motors, clearly.
  #26   Spotlight this post!
Unread 16-02-2012, 20:52
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: TOP HEAVY!!!!
Has it occurred to you to not go over the bump?
Use the ramps... or do you have a problem there too..??
Having those big CIMS up high is where to start... see if you can bring them down or use a lighter alternative motor...
But first put your bumpers on and see if you still have the problem
You don't have to go over the bump...
You can play the game by going over the ramps...
There is danger going over the bump... you can be defended and knocked over..(not as strategy...but defense being played....)
On your own ramp you cannot be defended...
just a thought...
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
  #27   Spotlight this post!
Unread 16-02-2012, 23:09
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Re: TOP HEAVY!!!!
Even with a complete robot, there's still a lot that can be reworked in most cases. First, make sure the heavy components (e.g., battery) are down low and ensure the heavier electronic components are lower on the side pieces.
Also, how offset are your wheels on the drive train? If they are more than 1/8", then you've probably put too much sway in the robot. Normally 1/16" offset is sufficient. This is especially true if your robot has the wide front and a narrower length.
Don't give up until the end of competition--I've watched a team build their entire robot at a competition site.
  #28   Spotlight this post!
Unread 17-02-2012, 11:31
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Re: TOP HEAVY!!!!
MATT look at your inbox!!! And we are not a rookie team for those who are wondering this is our first year with 6WD.
  #29   Spotlight this post!
Unread 20-02-2012, 09:52
Nikkocharger's Avatar
Nikkocharger Nikkocharger is offline
The R/C'er
AKA: Dontae
FRC #3398 (Crushing Crusaders)
Team Role: Mechanical
Rookie Year: 2012
Nikkocharger will become famous soon enoughNikkocharger will become famous soon enough
Re: TOP HEAVY!!!!
Originally Posted by Shaun Coon View Post
When we went to test it last night in the hallway we went half speed and it flipped nothing broke THANK GOD.
Wow lucky you, our collaboration robot went up the bridge and took a disastrous spill
Suddenly, a wild prototype appears!
