Go to Post You won't find this in a manual anywhere but you will need COUGH DROPS!! If you haven't started losing your voice by Friday afternoon, you aren't getting the full experience. - wendymom [more]
Unread 16-02-2012, 13:31
KyleS KyleS is offline
FRC #3016
KyleS is an unknown quantity at this point
Inverse Motors?
First time working with the WPIlib, not exactly sure how to inverse the motors when using the simple Arcade drive. Any ideas?
Unread 16-02-2012, 13:43
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
Rookie Year: 2011
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Re: Inverse Motors?
Use the RobotDrive::SetInvertedMotor(RobotDrive::MotorType , bool) function.
Something like:
Code:
//joystick - fill in usb port number
Joystick joy;
//declare jags - fill in ports in constructors
Jaguar left_front, left_rear, right_front, right_rear;
//declare RobotDrive object
RobotDrive drive(left_front, left_rear, right_front, right_rear);
//set motor inversion
drive.SetInvertedMotor(RobotDrive::kFrontLeftMotor, false);
drive.SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
drive.SetInvertedMotor(RobotDrive::kRearLeftMotor, false);
drive.SetInvertedMotor(RobotDrive::kRearRightMotor, true);
//drive
while (true) {
   drive.ArcadeDrive(joy);
Unread 16-02-2012, 13:54
FRC #3016
Post Re: Inverse Motors?
Exactly what I needed, thanks! Now all I need to do is figure out why the Axis Camera isn't working.
