Go to Post So kudos for asking advice... you've got plenty of good advice so far in this column... but honestly, if Orville and Wilbur Wright had taken good advice they would have packed up and gone back to their bicycle shop. - dtengineering [more]
Unread 16-02-2012, 14:05
tefangel's Avatar
tefangel tefangel is offline
AKA: K9M3
FRC #4043
Rookie Year: 2011
tefangel is an unknown quantity at this point
Question Controlled Acceleration using JAVA
I found a post similar to what I'm talking about, but it was directed towards LabView users.
Basically, I heard that there was a way to program the robot so that when a joy stick is moved all of the way forward, that the robot steadily accelerates instead of jerking forward and causing possible damage.
The sooner the response, the better! Thank you!
