Go to Post An annoyed inspector is a thorough inspector! - Jon Stratis [more]
Unread 16-02-2012, 15:26
powerrbill powerrbill is offline
FRC #0486
powerrbill is an unknown quantity at this point
Autonomous format
Hello again, CD! Another issue over here. We have finally moved to autonomous code, but we have no idea how to implement it in command structure. We are assuming it has a different setup than it would in simple because our Autonomous command does nothing. No errors, and no function. Best of both worlds .
Long story short, any help on Command structure autonomous?
Unread 16-02-2012, 21:22
jordangrant jordangrant is offline
JG2012
FRC #0610 (The Coyotes)
Rookie Year: 2010
jordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud ofjordangrant has much to be proud of
Re: Autonomous format
Hi there. I am not very experienced, but I think the autonomous section in the WPILib programming cookbook will be of great use to you.
Here is an example they give:
public class DriveInASquare extends CommandGroup {
public DriveInASquare() {
add(new DriveStraight(1));
add(new Turn(1));
add(new Turn(1));
add(new Turn(1));
What you're doing is basically creating the autonomous command schedule and specifying certain values manually. It's very possible that you already know this but I hope this helped a little bit.
