Go to Post Honestly I'm looking forward to just seeing all my friends again, that's what FIRST is really about to me. - Barry Bonzack [more]
Unread 16-02-2012, 22:18
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
Rookie Year: 2010
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Honeywell Microswitch (Limit Switch)
I need to know how to program the microswitch so that when the lever is pushed down the light on the top pane of the drver station application lights up or somehow signals that the lever has been pressed.
Unread 17-02-2012, 17:37
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Re: Honeywell Microswitch (Limit Switch)
+1 for that. I want to know that too!
(while somewhat [not really] on the topic, we need a +1 button for when we want to know the answer too...)
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 17-02-2012, 17:55
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
It used to be that a couple years ago, there was sample code provided by FIRST that allowed you to send all your digital I/O, analog input data etc to the dashboard (DashboardDataFormat::SendIOPortData()). After kickoff this year, I briefly played with the code from two years ago and it did not work. I did not have time to figure out why. It is probably because the Dashboard data format has changed and we need an update to that sample code. You may look at it along that line.
However, there are many ways to feed the information back to the driver station. One of the possibilities is the DriverStationLCD class. If you are interested in that, I can explain how to use it.
Unread 18-02-2012, 10:19
dmitch's Avatar
Rookie Year: 2010
I would appreciate if you could explain the DriverStation LCD class. We're using the switch for if the ball is at the correct position to shoot, so a simple output like "Ready for Shot" or something along those lines would really help. Thanks!
Unread 18-02-2012, 13:54
mikets's Avatar
Software Engineer
You can paste the following macros into your file and use them. Note that these set of macros make life easier but the double paranthesis on LCDUpdate is required to make the macro work. You only need to call LCDUpdate once per loop. It refreshes the message display on the Driver Station. In other words, you can call LCDPrintf on several things, one per LCD line and then call LCDUpdate once to "deliver" the lines to the driver station.
Code:
#define LCD_LINE1               DriverStationLCD::kUser_Line1
#define LCD_LINE2               DriverStationLCD::kUser_Line2
#define LCD_LINE3               DriverStationLCD::kUser_Line3
#define LCD_LINE4               DriverStationLCD::kUser_Line4
#define LCD_LINE5               DriverStationLCD::kUser_Line5
#define LCD_LINE6               DriverStationLCD::kUser_Line6
#define LCDPrintf(p)            DriverStationLCD::GetInstance()->PrintfLine p
#define LCDUpdate()             DriverStationLCD::UpdateLCD()
class MyRobot: public SimpleRobot
public:
    MyRobot()
    ~MyRobot()
    void Autonomous(void)
    void OperatorControl(void)
        while (IsEnabled() && IsOperatorControl())
            LCDPrintf((LCD_LINE1, "ReadyToFire = %d", m_switchState));
            LCDUpate();
