Go to Post Got Valentine's day present from wife before leaving for work. Non-contact IR thermometer, two unscuffed pairs of safety glasses for competitions, bag of York peppermint patties. She understands me. - Greg Young [more]
Unread 16-02-2012, 22:28
dwmcc dwmcc is offline
FRC #2192 (YAK Attack)
Team Role: Leadership
dwmcc is an unknown quantity at this point
On Button press, run a sequence (Not momentary!)
As the title suggests, I'm trying to figure out how to run a sequence of events (Actuate solenoid, get reed switch value and when it's true, stop solenoid) on a button press. I've tried a structure, but I can't figure out how to run a sequence of events on a button press. This issue I'm running in to is that since a button press is momentary, the sequence begins to run, but when the button is released, the sequence stops.
Any ideas?
Thanks so much!
dwmcc
Unread 16-02-2012, 23:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: On Button press, run a sequence (Not momentary!)
The Flat Sequence structure is a natural for sequences of events. Each frame of the sequence will run in turn as the previous frame's functions complete. Put one in a neverending While in the Periodic Tasks vi, and make the first frame wait for the button press.
Unread 17-02-2012, 18:56
Thank you both for your reply. Alan, I have inserted my code into the Periodic Tasks vi in a neverending while loop, but how can I tell it to run it when I press the joystick button?
Thanks!
dwmcc
Unread 18-02-2012, 00:33
Software Architect
Try this.
Name:	solenoid sequence.png
Unread 18-02-2012, 14:21
Try this.
Thank you so much! Worked perfectly.
Unread 19-02-2012, 12:27
gabrielc97's Avatar
gabrielc97 gabrielc97 is offline
AKA: Gabriel
FRC #4029 (Spartan Bots)
Rookie Year: 2012
gabrielc97 is an unknown quantity at this point
[quote=Alan Anderson;1129266]Try this
how can i program this to control a motor?
Gabriel
Unread 19-02-2012, 12:52
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
[quote=gabrielc97;1130131]
Try this
Change the DIO VIs to MotorControl VIs, with parameters controlling it as you need to?
Unread 19-02-2012, 13:03
gabrielc97's Avatar
AKA: Gabriel
Rookie Year: 2012
[quote=Pirate programe;1130143]
Thanks! we'll try that.
Gabriel
Unread 16-02-2012, 23:03
compboy07's Avatar
compboy07 compboy07 is offline
AKA: Jake M.
FRC #2449 (Out of Orbit)
Team Role: Electrical
Rookie Year: 2011
compboy07 is on a distinguished road
try something like this psuedocode, point being use an 'isActive' type boolean. If you're using labview, you'll have to look at this yourself, and find a similar concept (never used it)
bool solenoidRunning = false; //at init
//following in main loop
if (!solenoidRunning && buttonPressed){
solenoidRunning = true;
activateSolenoid();
} else if (solenoidRunning && switchActivated) {
stopSolenoid();
Edit: Sorry, forgot to look at the forum category...
