Go to Post Be watchful of the "man this is so cool we should do it in build" as I've embarrassingly fallen victim to it so many times before, with varying results. - Aren_Hill [more]
Unread 16-02-2012, 22:38
zero118 zero118 is offline
FRC #2410
zero118 is an unknown quantity at this point
Using Proxy Switch to Calculate RPM
Hello,
Our team is currently attempting to calculate the rpm of a wheel by utilizing a proxy switch. We will then use this calculated rpm with a PID loop do acquire a desired rpm; however, I am struggling to calculate the rpm in labVIEW.
I first tried to use the counter VI, a sequence structure, and a timer delay function, but I ran into problems (all these calculations are occurring in the teleop VI)
Here is the program i am using to calculate the rpm
Apparently the wait function I have in there makes the entire robot inactive.
How do I approach this problem?
Thanks!
