Go to Post "It is a guaranteed fact that at least one rookie team will name their robot 'Chuck Norris'." - Tim Arnold [more]
Unread 16-02-2012, 23:13
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
pic: Mini Octocanum Drive Module
Unread 16-02-2012, 23:16
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Re: pic: Mini Octocanum Drive Module
Wow! does this go over the bump? does it have tipping problems with the wheels being ultra close together? I am scared for 10,000 lakes now
We haven't finished the shooter yet, but It should be all working by tomorrow! Hopefully we will have a chance against you guys!
I also hope we pick you (I guy can dream right )
2011 Record (11-3-0)
Unread 16-02-2012, 23:33
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
beautiful - awesome design!
Fast, cheap or working - pick any two!
Unread 16-02-2012, 23:36
No, we don't go over the bump - bridge only. We wanted a very low center of gravity to help balancing on the bridge. It goes across the bridge easily on the small Colson wheels.
Unread 18-02-2012, 23:13
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Having just seen this drive move, I really like what it can do. The mecanum half is very fast and smooth, and I really like the slightly faster gearing as compared to your 2010 and 2011 drives. It switches to traction mode quickly and smoothly and looks terrific going up a ramp.
The question I had was "How are you getting the Colson wheels to move in an arc using cylinders that are pushing in a straight line?" The answer made sense but was simpler than I expected.
Unread 19-02-2012, 06:47
The cylinders are perpendicular to the centerline between the two mecanum wheels. The bracket which moves the Colson wheels swings on an arc which is centered above and below the mecanum centerline. The cylinder is positioned at the midpoint of this arc to minimize the error and then the bracket holes are oversized slightly to accomodate the error.
Unread 20-02-2012, 19:45
A report from our local paper at our open house yesterday. They were kind - they only showed shots we made. A local TV station did a report and only showed shots we missed.
http://wcfcourier.com/video-cf-robot...9bb2963f4.html
