Go to Post The weight sounds about right, too. If you need more than 65 pounds for your manipulator, then the drivetrain isn't the part you should be redesigning... - s_forbes [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:50
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Suppose you want seat motors...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 1/27/2000 6:00 AM MST
The seat motors are used no many (though not all) GM models with power seats.
I don't know ALL of them, but I know that the Safari Van I am currently driving uses these motors. It is a 1999 Model Year GMC Safari.
This motor is a few bucks less than the old motor so look for it on newer vehicles. As GM turns over its designs, the newer ones will be more likely to use the less expensive motors.
If others find other models that use the same motor, please let us all know.
Joe J.
P.S. FYI, the motors are essentially bolt-in replacements for the motors that have been used in FIRST for years. If you want motors to prototype with, you can't really go wrong using the old motors from ITTA.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
