Go to Post Remember, FIRST is a great opportunity that will get you ahead in the long run but don't forget about the short run either. - ChrisMcK2186 [more]
Unread 17-02-2012, 11:57
brunoUC's Avatar
brunoUC brunoUC is offline
AKA: Bruno Toso
FRC #1156 (Under Control)
Rookie Year: 2011
brunoUC is an unknown quantity at this point
stand alone build error 7
hi, i'm trying to deploy our stand-alone code but i keep on receiving this error messege:
Error 7 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
thanks
Unread 17-02-2012, 12:05
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: stand alone build error 7
We sometimes get build errors "like" this, and they can be a little fun for troubleshooting. I believe that if you get an Error 6 it is caused by inadequate file permissions (trying to send your build file to a protected folder) so to fix that one method is to run Labview with admin rights and that works normally.
Alternatively (I think it's an Error 7 but I could be wrong) sometimes the build folder is in the wrong location, depending on how you have configured the project.
Open your Project and click the plus sign next to Build Specifications and right click on FRC Robot Boot-up Deployment and click Properties. Select the Information Category on the left and under the field "Local destination directory" is the folder where Labview stores the build file. Make sure this folder exists, for me I have the following contents in this folder:
Folder - c (folder for cRIO build files)
Folder - FRC Dashboard Project (folder for Dashboard build files)
