Go to Post - Only think of Gracious Professionalism as a standard to work toward personally. - Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 17-02-2012, 16:43
Gizmo4 Gizmo4 is offline
FRC #9999
Team Role: Student
Rookie Year: 2012
Gizmo4 is an unknown quantity at this point
Bumper problem?
How have teams with a hole (to gather balls) in the front of their frame attached bumpers to the left and ride sides? There are a bunch of bolts in the way that holding the corner of the frame together in the way of the U channel, so our piece of u channel wont slide over the U channel already on the frame, and therefore won't be able to secure the bumper in place.
Our frame looks like this, with the hole in the front.
bolts in the way, where we want our two 8 in bumpers to go
Unread 17-02-2012, 16:50
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Bumper problem?
We put vertical sections of square tubing in the corners, with L brackets on the bumpers. Sink a rivet nut or pem nut into the tubing, and bolt the L bracket to it when you put the bumpers on. We have additional C-channel that slides over the frame more in the middle to help keep everything stable.
Unread 17-02-2012, 18:34
FRC #9999
Team Role: Student
Rookie Year: 2012
Re: Bumper problem?
Thanks, but what if my rookie team doesn't necessarily have any square tubing? And approximately how thick does it have to be (or how thick was your teams tubing) in case we go out and buy it at, say, Home Depot? Not positive if we do or not, probably don't. Your team's square tubing is steel/aluminum right? We should at least have L brackets and rivets though.
Unread 17-02-2012, 20:45
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Re: Bumper problem?
In our rookie year, we put some of these in our bumper wood and put bolts in through them (so that the bolt head was inside the bumper). Then we put the bolts through the c-channel and used wing nuts to secure. This was a very easy way to do it.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 17-02-2012, 21:30
FRC #9999
Team Role: Student
Rookie Year: 2012
Re: Bumper problem?
Thank you, I'll have to try one of those ways with my team.
