Go to Post Because it's a fun challenge. Kind of like Sudoku, but with lexan and evil geniuses. - nathanww [more]
Unread 17-02-2012, 18:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Team Update 2012-02-17
GAME - Team UPDATE - 2012-02-17
Power Distribution
[R44]
All active circuits shall be wired with appropriately sized wire:
Application
Minimum wire size
40A circuit
12 AWG (2.052mm)
30A circuit
14 AWG (1.628mm)
20A circuit
18 AWG (1.024mm)
between the PD Board and the Analog and/or Solenoid Breakouts if a common power feed is used
between the PD Board and the Analog and/or Solenoid Breakouts if individual power feeds are used
20 AWG (0.8128mm)
between the PD Board and the cRIO
between the PD Board and the wireless bridge
between the PD board and 5A custom circuits
pneumatic valves
24 AWG (0.5106mm)
The branch circuit may include intermediate elements such as COTS connectors, splices, COTS flexible/rolling/sliding contacts, and COTS slip rings, as long as the entire electrical pathway is via appropriately gauged conductors.
Wires that are originally attached to legal devices are part of the device and by default legal as supplied. Such wires are exempt from Rules [R44] and [R45].
And that's the entire update. That's a very reasonable change to make--exempting motor leads from the color requirements (which don't apply to them anyway due to motors not having constant polarity).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-02-2012, 12:44
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Re: Team Update 2012-02-17
Are you talking OEM wires attached to a motor? I wonder if we can use speaker wire that is not read/black for motors?
TIA
Fast, cheap or working - pick any two!
Unread 19-02-2012, 13:00
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
TIA
The update seems to only apply to that OEM wire with the keywords of "wires that are originally attached."
