Go to Post I'm gonna go back to my corner and write some more code... - Kevin Watson [more]
Unread 17-02-2012, 19:07
Hebrew Hebrew is offline
FRC #4228 (iRobotics)
Rookie Year: 2012
Hebrew is an unknown quantity at this point
Carpet at Competition
Hi,
I am part of a rookie team. We didn't get as far as I wold have liked this year but we managed to get a working robot, it can't shoot very well so we will just be doing defense. We recently took our robot to our schools library to test it out on carpet but it could not turn at all. The robot locks up and will not move for a small amount of time. The carpet that we used it on is a short, harder style carpet. We tried putting masking tape on the wheels. The masking tape ripped off very fast. We put duct tape on the wheels and it just spun out which would not work playing defense. We put some sand paper on the wheels and it could not turn.
Our robot is just right in the dimension limits and is operating with the wheel from the KOP. It is a tank drive with a motor on each side toward the back of the robot.
What I the carpet like at the competition?
Is there anything we can do to fix the wheel problem fairly fast? We are going to a scrimmage tomorrow.
Thanks.
Unread 17-02-2012, 19:11
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Carpet at Competition
If we could have some information about your drivetrain we could also help. As well, I don't believe adding tape is the way to go to increase traction.
To answer your question about the competition carpet, as per Section 2, The Arena,
The Court is covered with carpet (Shaw Floors, Philadelphia Commercial, Neyland II, 20, 30753, “park bench”).
This is the carpet to be used at competition.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 17-02-2012, 19:12
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The competition field is going to be pretty much what you tested on.
As for traction, try this classic trick:
1) Get lots of zip ties.
2) Place the zip ties on the rims of the wheels on one end of the robot.
3) Replace any zip ties that come off.
You could also:
--Add a dropped center wheel (if you're using the KOP frame, the center hole on the side rails is dropped down slightly already).
--Change one end for omni wheels (more expensive, and you'd have to wait for them to arrive).
--Add a CIM to each side and make sure all your wheels are powered.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Add a motor to each gearbox.
Are you using 6 wheel drive?
2001-2004: Team 100
2006-Present: Team 254
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
What drivetrain setup are you running. We ran into the same problem and had to switch to a gearbox with a higher gear ratio.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 17-02-2012, 19:26
Rookie Year: 2012
We probably do not want more traction if the wheels lock up, do we?
We are using four wheel drive and the frame is the standard from the KOP. Will six wheels really increase the chances of turning?
All of our wheels are getting powered from the two motors.
Unread 17-02-2012, 19:29
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Yes, plant two powered wheels in the center holes of the KOP frame. Those two holes are lowered, which is why this will work. (You shorten your wheelbase a little bit, which really does help.)
Past teams:
Unread 17-02-2012, 19:32
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
If you can switch to 6 wheel center drop, then yes, it will turn easier. The idea behind center drop drive trains is that it shortens the distance between the wheels on the ground and so they can turn easier. In standard 6 wheel drop, there will always be 4 wheels on the ground and it will "rock" when it turns and/or drives.
As well, if you can change it to 4 CIMs, it will be much easier to play defense.
My personal opinion would be at least ensure your ball manipulator can shoot balls enough that you could feed to your alliance partners from the opponents zone, keeping in check the various penalty rules
Unread 17-02-2012, 19:37
Rookie Year: 2012
So all we do is hook up the two wheel like the pervious four, add a sprocket and we are good to go? Or is there something fancy to do? (No one is currently at the robot so I cannot check myself and we will be doing this immediately tomorrow morning).
Is there extra sprockets in the KOP?
Edit: I am not on the build team so some of my questions might be silly, but they didn't do it so I am switch I am helping out since I have nothing else to do
Unread 17-02-2012, 19:51
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Nope, nothing fancy. The bad news is that only 4 sprockets came in the KOP; for a short-term solution, move the wheels on the light end of the robot to the middle and have the wheels at that end unpowered until you can get sprockets in. (The KOP sprockets can be found at http://www.andymark.com/product-p/am-0737.htm for $9+shipping; I'd get 4 so you can have a shorter chain run to the front wheel.)
Past teams:
Unread 17-02-2012, 19:58
Rookie Year: 2012
Ah, so we split our long chain into two medium chains for each side.
Is there absolutely no temporary solution for a four wheel drive so we can still do decent at the scrimmage we are going to tomorrow?
Unread 17-02-2012, 20:04
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Yep, move the powered wheel to the center and leave the light end unpowered.
Or, as I noted earlier, wrap zipties all around the rim of the light-end wheels. That's one of the oldest tricks in the book, and it works as a temporary measure. (Or a permanent one, in some cases.)
When I say "light end", often robots (particularly 6WD robots) will have one end heavier than the other, which means the CG is slightly to one end or the other. The wheels where the CG is not tend to carry less weight, so modifying them is less detrimental to traction.
Past teams:
Unread 17-02-2012, 20:07
Rookie Year: 2012
Thanks for the help, we will try the zip tie thing tomorrow and then as a last resort unpowered six wheel drive.
Unread 18-02-2012, 02:15
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Thanks.
That's the good news. At the scrimmage there will be a lot of people who will be happy to help. They may even be able to supply the mentioned zip ties for you. Don't put the "fat" ends on the bottom!
BTW, the reason the zip ties work, is that they will act like little skis for sideways movement of the wheels and reduce the forward/backward traction an acceptable amount. The reason you're having difficulty steering is the traction between your wheel and the carpet is pretty much the same in all directions and turning tries to make the wheels to go side to side against that traction.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
  #15   Spotlight this post!
Unread 18-02-2012, 21:36
Rookie Year: 2012
If you are interested:
At the scrimmage instead of using zip ties we used electrical tape on the wheels to assist in turning. We only did four matches because we were also testing drivers and two of them destroyed our pistons by running into the bridge which really slowed us down. We fund that the tape worked fairly well if used on two wheels but had to be replaced after each match because it loses it's slip. We will be testing zip ties out on Monday or Tuesday.
