Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 17-02-2012, 21:24
ElmoLibre ElmoLibre is offline
FRC #3408
ElmoLibre is an unknown quantity at this point
Vision in Robot Main Not Working
So, running the support "Rectangular Object Tracking" code works perfectly. However, when I try to copy it directly over into my Robot Main project. Unfortunately, when I do that, it stops reading the camera inside the code itself. Images still show up on the Dashboard, but not inside the Vision Processing code itself. If anyone has any ideas on how to get it to work, it would be greatly appreciated.
If we copy the rest of our code into the support code, it works just fine. However, we can't set support code to run as start-up, so I want to be able to have vision in our actual code, rather than in a temporary testing place. Thanks!
~Team 3408 Software Team
Unread 17-02-2012, 21:30
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Vision in Robot Main Not Working
Don't change or touch Robot Main.vi
All your changes should be made in the Team Code section only.
Unread 18-02-2012, 14:00
FRC #3408
Sorry for the miscommunication. We have been putting code into the Team Code section. I was just wondering if there was any reason why taking the vision sample code and putting it into our own code wouldn't work.
Unread 18-02-2012, 20:48
rivasm rivasm is offline
FRC #2556 (RadioActive Roaches)
Rookie Year: 2010
rivasm is an unknown quantity at this point
Go to the code you want to integrate. Go to the robot main. Double click on the Vision block. "Save as" and select the hierarchy option. Save it in the code folder you are integrating it into. Open the folder you just saved which is inside of your code folder. Cut all of the files from that folder, and paste them inside the actual code folder. I'm probably not explaining this very clearly, and I can rephrase or post pictures if needed, but I really hope I answered your question.
