Wiring the GTS from the 2008 KoP
We are planning on using the Gear Tooth Sensors from the 2008 KoP with this year's robot. The sensor uses both a Digital I/O connector to connect to DIO on the sidecar, but it also requires a 12V power supply. Where should this 12V supply be connected?
