Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
  #16   Spotlight this post!
Unread 13-03-2012, 23:45
johnmaguire2013's Avatar
johnmaguire2013 johnmaguire2013 is offline
Harps On Websites
AKA: John Maguire
FRC #3322 (Eagle Imperium)
Team Role: Webmaster
Rookie Year: 2011
johnmaguire2013 is an unknown quantity at this point
Re: Team 3322's website
O.o Canary, huh? Odd as it works in the stable version of Chrome and is done using a z-index... you sure this isn't an issue with Canary itself? I will look into it and try to fix it. Thanks for the bug report either way, and thanks for the compliments.
And I feel I must apologize for the small width on your large monitor. I don't have a monitor large enough to know... how often do you come across fixed-width small layouts? Again, I wasn't a part of the initial CSS process, so I didn't have a lot of control over that, but I <3 fluid layouts.
John Maguire
Website Team | PR/Marketing Team
FRC Team 3322 - Eagle Imperium | My Blog
  #17   Spotlight this post!
Unread 14-03-2012, 20:25
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
It's not an uncommon situation, honestly. It feels like almost every site is formatted like that- though it does make it easier to throw up two windows at once
Seriously, though, Chiefdelphi does it, Google Plus does it, Facebook does to a degree, and a lot of other blogs. Not a problem.
And yeah, I use Canary... generally it doesn't cause formatting errors for me, though. Just crashes more often, and uses more CPU. And remember, what is Canary today is chrome standard in 2 months or so...
  #18   Spotlight this post!
Unread 17-03-2012, 09:43
Harps On Websites
AKA: John Maguire
Rookie Year: 2011
Haha, fair enough. I just prefer fluid layouts.
Yeah, I know, I used to run Canary. Although "Canaray today is Chrome standard in 2 months or so" is more of "A fixed out-of-beta Canary today."
Do you mind telling me what you see on this website?
John Maguire
  #19   Spotlight this post!
Unread 17-03-2012, 10:11
Harps On Websites
AKA: John Maguire
Rookie Year: 2011
Also, can you try our site again? I made a change, but I can't test as my good laptop died, and I'm having to use this temporary one... which can't run Chrome. -_-
John Maguire
  #20   Spotlight this post!
Unread 19-03-2012, 18:44
Dusk Star's Avatar
AKA: Andrew
Still has the "hiding behind image and text" problem, unfortunately...
And the "John Maguire" page says
Nothing Found
Sorry, but I couldn't find any posts matching your criteria.
Name:	skyline robotics webpage2.png
  #21   Spotlight this post!
Unread 21-03-2012, 11:29
Harps On Websites
AKA: John Maguire
Rookie Year: 2011
Indeed. I've been unable to find the cause of the Canary bug. It uses z-index to ensure the menus stay on top, and I have no idea why it would be falling behind. I even did some test cases and it worked fine. Very odd, and I'm still looking for a solution.
Thanks for the tip on the broken page. Apparently we removed last names from the site recently due to liability reasons(?) and so some links got broken. We even have a broken link checker, so I'm not sure how that slipped through.
Thank you very much.
EDIT - And in fact, the link is not broken. You may have tried accessing the site while we were updating, or we fixed the broken link already. If you still see the problem, a hard refresh should fix it.
John Maguire
  #22   Spotlight this post!
Unread 21-03-2012, 13:08
Dusk Star's Avatar
AKA: Andrew
Link still shows as broken. This is ie8 on xp- fairly standard!
However, your team site works with this browser, and chrome portable. So I guess that is just canary chrome's fault!
  #23   Spotlight this post!
Unread 23-03-2012, 14:51
Harps On Websites
AKA: John Maguire
Rookie Year: 2011
Sorry, thought you were referring to a different page. I tested the test.html in Canary and then deleted it without letting you know -- my apologies!
Aye, the menu links issue only shows up in Canary, and I'm still not quite sure what's going on with it. :\
John Maguire
  #24   Spotlight this post!
Unread 23-03-2012, 17:16
Dusk Star's Avatar
AKA: Andrew
Ah, that's not a problem. I have far more time than I know what to do with at school, anyways.... Two online classes, both of which take about three weeks a semester (of dedicated work, though), and a severely locked down internet connection = not much to do
Nice custom theme, by the way!
