Go to Post I'm not worried about the amount of Segways at a regoinal, I'd rather see them out in the real world than at a robotics competition. - Joe Matt [more]
Unread 17-02-2012, 22:59
GilaMonsterAlex's Avatar
GilaMonsterAlex GilaMonsterAlex is offline
Lead Team Mentor
FRC #3785 (Gila Monsters)
Rookie Year: 2011
GilaMonsterAlex is an unknown quantity at this point
Bridge Lowering Device??
So our team has prioritized our goals and to be honest, the bridge lowering device was on the last of our list after practicing. Our thought was if we can't shoot then we're not as effective on the team, and if we coordinate with another team member we can piggy back on their getting on the bridge.
THe question is: is there a huge problem with not having a bridge lowering device?
We do understand that being self sufficient is good, but as I mentioned it was on our low end of the priority list. We can still add a mechanism, during our waiting and include it to our hold back.
Your thoughts?
Unread 17-02-2012, 23:04
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
Rookie Year: 2010
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
Re: Bridge Lowering Device??
Eh, it wouldn't feel right attending a competition and not being able to handle each aspect of the game independently.
Unread 17-02-2012, 23:11
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
What we did was hook up the andymark motor with the planetary gear on it with a flexible collar on it to lower and raise a ram I can show pics tomorrow
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 17-02-2012, 23:23
Lead Team Mentor
Rookie Year: 2011
Yeah, it's kind of what's bugging me. We'll see what we can do. We're pretty close to the weight limit but I believe we're ok.
Thanks, we're already using that motor/gearbox tho. We've got some ideas but didn't get to them.
Unread 18-02-2012, 00:55
Pun-isher's Avatar
Pun-isher Pun-isher is offline
Gotta Go Fast
AKA: Shakeel Madhav
FRC #1759 (P.O.T.A.T.O.E.S.)
Team Role: Driver
Pun-isher is an unknown quantity at this point
It would be nice, but at this point, focus on what you have and improve on the bot. If you absolutely need something to do and are done (which, if you do, I envy you), then do some research - you'll be surprised at how simply you can lower the bridge, and get on it. But that's an extreme scenario.
Unread 18-02-2012, 09:18
ThaineP
Posts: n/a
I'd say that it's not necessarily required to lower the bridge, but it would obviously be advantageous. If your shooter can reach the other side, then you do not have to cross the bridges. However, the balls they return will be injected into the other side, so unless you have a team member passing them to you (which reduces efficiency) you will only be able to shoot the few that migrate to your side, or those that are scored on you.;
Short answer: Yes.
Unread 18-02-2012, 12:41
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Rookie Year: 2010
Wolfgang is an unknown quantity at this point
If you can just cross the bump, then the bridge is very much optional.
Unread 18-02-2012, 15:08
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Except for endgame points
Fast, cheap or working - pick any two!
Unread 18-02-2012, 15:15
frasnow's Avatar
frasnow frasnow is offline
Software
Rookie Year: 2010
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
The Suffield Shakedown scrimmage appears to indicate the endgame is really important. Most matches I watched on the webcast could have been (or were) changed by a single robot balancing.
Unread 18-02-2012, 15:18
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Not gonna stay that way, though. Week 0 events aren't known for everyone being fully functional.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 18-02-2012, 16:17
Rogue Leader Rogue Leader is offline
FRC #0696 (Circuit Breakers)
Rookie Year: 2011
Rogue Leader is an unknown quantity at this point
Not having a bridge lowering device wouldn't be terrible, so long as you could drive over the barrier and get on the bridge at the end of the match with the help of fellow alliance members. Not having one isn't going to be the end of the world. XD
Unread 18-02-2012, 16:38
Lead Team Mentor
Rookie Year: 2011
An that was/is our original goal. We were hoping to piggyback onto the ramp with a teammate it's not like two can use the lowering device and we imagine most teams will only do two robots per bridge (usually). We will work on it after bag and tag and add it afterwards. We'll do a nice engineering study on maximizing force and minimizing weight since we're about 10lbs shy of 120.
2014 - AZ Regional Finalist
2013 - AZ Regional Finalist
2013 - AZ Gracious Professionalism Award
2011 - AZ Motorola Quality Award
Unread 29-02-2012, 14:44
rockytheworm's Avatar
rockytheworm rockytheworm is offline
AKA: Chris Kirk
FRC #1517 (Lumberjacks)
Rookie Year: 2011
rockytheworm is an unknown quantity at this point
Our bridge lowering device broke during week zero matches so our driver took it upon himself to endo onto the bridges for final balancing... needless to say he drives like he stole it
