Go to Post Side effect include: Hearing loss, splinters, blisters, extreme sprit, uncontrollable urges to scream "GO MOE", and bright green fashion sense - The Lucas [more]
Unread 18-02-2012, 06:50
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
How to control PG71 gearmotor
I have an arm on the robot and I don't know how to control the PG71 motor that drives it? Do i connect to to a Jaguar? I kind of figured out to program this stuff, but this is my first year and I was put in charge of this.
Unread 18-02-2012, 08:35
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Either a Victor or Jaguar (speed controllers) will do. From the sounds of things, you'll want to plug a PWM cable into the speed controller and the other end into the digital side car. The number on the digital side car corresponds to which output to specify in your program. Check the FRC website under kit of parts for more information. There's a document called something like "Getting Started with the Control System". This has lots of good information.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
