Go to Post This is a solemn reminder of how fast time goes by with the blink of an eye, that if you don't run to catch up with it, it will catch up with you and sweep you away. - Ken Leung [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:51
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Machine weight and holes
Posted by Susanne Krussell.
Coach on team #349, Robahamas, from International Academy and Ford Motor Co..
Posted on 1/27/2000 6:37 PM MST
After reading the latest questions posted by FIRST (#136, 136), and with a good deal of amusement, my co-coach Bethany and I would like to remind Daniel on Team 483 that if he decides to reduce robot weight by drilling holes in the pneumatics tank, his team will be able to keep a fairly steady pressure of 100 kPa (1 atm).
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
weight problem. archiver 2001 10 23-06-2002 23:13
good idea or bad? archiver 2001 4 23-06-2002 23:08
Go Home Device Advice? Eric Reed Technical Discussion 8 18-03-2002 08:14
weight advice SharkBite Technical Discussion 36 15-02-2002 07:30
