Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
Unread 18-02-2012, 09:57
arrou.keys arrou.keys is offline
None #1100
arrou.keys is on a distinguished road
Exclamation How do you wire a VEX motor to a 12 V battery?
Morning, everyone! Hope the robots are almost all done!
How do you wire a VEX motor to a 12 V battery? A Vex motor takes only 7.2 volts. Would you have to use a Circuit Breaker on the PD Board with it? A Jaguar or Spike Relay?
Thanks!
Unread 18-02-2012, 10:07
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How do you wire a VEX motor to a 12 V battery?
You would use a Spike or a Jaguar or a Victor or a VEX Speed Controller (the small one that came in the KOP).
If you use a Spike, it will get full battery voltage...which may or may not be a problem, depending on how you load the motor (what the shaft is connected to)
Unread 18-02-2012, 10:12
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Normal operation would be to connect the 2-wire motor to the Vex controller.
The Vex controller connects to a PWM output on the Digital Sidecar.
A jumper by the PWM output feeds it 6v.
You command it in code just as you would a Victor speed controller.
None #1100
How do you wire a VEX Speed controller? Do you need an additional Jaguar or Spike Relay for that?What type circuit breaker would you have to use - 40, 30, or 20 amp?
I'm not planning on using a Spike Relay - I don't want more than 7.2 volts on the motor.
Unread 18-02-2012, 10:57
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
Rookie Year: 2011
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
As Mark and squirrel said, the 2 wire VEX motor plugs into the 2 wire side of the VEX motor controller. The 3 wire side then gets plugged into a standard 3 wire spot on your digital sidecar.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
