Go to Post Load the whole bot up with all 22 motors, put them all into the drive train. Oh yes. - Grim Tuesday [more]
Unread 02-18-2012, 12:46 PM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Braking with victors
2 pretty basic questions for you guys:
1.How have you managed braking so far with victors? We only have 4 jags (set up with driving) and using victors for an arm-type apparatus. We'd like to set it up so that we can stop the arm in different positions (using encoders to measure the distance) but braking with victors seems to be ineffective. Nothing happens in term of stopping the motors. The just stop outputting, and our arm falls down. Id really like some way to hold it still in one position like brakes in the jags. Is there a known way to do this>
2.For some reason initializing a victor and running victor.set(speed) does nothing for us, but initializing them as a RobotDrive works. This seems like there is something different about RobotDrive, because we use the same inputs on both. Whats the best way to use victors in the wpilibj libraries? Or do you make a class for it?
Unread 02-18-2012, 12:52 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Braking with victors
The brakes in the Jags provide dynamic braking only, not static braking. Unless you have a high gear ratio gearbox that doesn't backdrive easily, the Jags won't hold it either.
What motor are you using, and what total gear ratio (gearbox plus any sprocket ratios), and what is the magnitude of the torque required to hold the arm?
Unread 02-18-2012, 03:53 PM
AKA: Joel Gallant
Rookie Year: 2012
Gearbox ration is 256 - 1
I don't really know what the motors are, but they are really powerful.
Dont know the torque either.
Unread 02-18-2012, 05:08 PM
Ether's Avatar
Rookie Year: 1969
If you are using really powerful motors with a 256:1 gearbox to lift an arm, you better know the torque. There's a torque limit on those 256:1 gearboxes, and it's a lot lower than you might think.
Unread 02-18-2012, 06:08 PM
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
Rookie Year: 2010
jesusrambo is an unknown quantity at this point
If you have an encoder on your motors you can use a PID controller to hold them in place.
Unread 02-19-2012, 12:58 AM
AKA: Joel Gallant
Rookie Year: 2012
Yep. Our team learnt that today. Broke a gearbox. I know, derp-di-derp. Were a rookie team.
